Install Manager Login Down?
2»
  • Looks like the DIM login is working for me now! *thumbs up*
  • barbultbarbult Posts: 27,113
    barbult said:
    Daz Studio won't even open for me. It has been stuck on Loggin in... for several minutes. (I have autologin enabled.)
    The release build will keep trying to log in, the beta has a timeout so it should stop and go on to work offline.
    I'm running beta 4.9.3.71. It does not timeout, as far as I can tell. At least not for 10 minutes. I gave up after that and killed it with Task Manager. It is working OK again now. The first thing I did was turn OFF auto login. I haven't updated to the newer betas, because I don't have a 10 series graphics card, and I saw some troubling comments about new bugs in the new betas.
  • Finally! Successful login. Yay!
  • AlfawulfAlfawulf Posts: 174
    Yay!!
    It appears to be good!!
    A hiccup from some behind the scenes tweaking perhaps??
    It was in the most recent beta or two that this was added, so you won't have it. Unless you are using a Mac or an older (AMD?) CPU the major bugs in the betas with Pascal support shouldn't affect you - at worst you may need to update your video driver.
    Thanks, Richard. I have an Intel CPU on a PC. I had also heard that displacement wasn't working correctly. I generally hate the use of displacement in Iray, because of the high subD required to get very good results. So maybe I shouldn't let that issue deter me. Maybe I'll go ahead and give the newest Beta a try.
  • SaphirewildSaphirewild Posts: 6,729
    I am having simular issues with DIM and Daz Studio when trying to log into the store in Daz itself my Daz shuts down and gives me a log file!!!
    Went to try to buy and download stuff today and DIM will not sign in.
