suddenly my genesis 3 female is grey block
kerabera
when i try to load a genesis 3 female,she is only in grey block.....but all other character gen2 male,female and gen 3 male are ok......
my modified gen3 female are ok too,but not the girl from the default file genesis3female.duf
i re-install 2 time all daz repertory (software and add-on content) and that doesn't work.
what happened ?
I've removed your image as we don't allow unclothed characters with skin texture - if you needed to show the state of the scene it would be better to switch to smooth shaded view.
Since the other figures load correctly it obviosuly isn't view style - are you getting the missing asset pop-up when you load your figure? That would usually indicate that the files in the \Data folder were missing or misplaced - it loked as if you had G3F installed to the same content directory, though, so that is odd. Did you install manually or with Install Manager? Where is the content and what are your content directories (Edit>Preferences>Content>Content Directory Manager)?
remove my picture ? it was the default genesis character .....
Yes, which has a skin texture applied and therefore cannot be shown in the forums, in textured mode, unless clothed.
i finally found the solution by copy-past each file one by one and test between my files on computer and file from clear installation on other computer.
it appear that the file mydaz3dlibrary>data>daz3d>genesis3>female>genesis3femalle.dsf on my computer was changed.it take only 441ko while the same file after install take 772ko.
by replace it there are no more problem.
but i really don't know what happen.why,when and by what,the original daz file was modified.
