Poke through in crotch area Gen 3 female
rampart_1576840087rampart_1576840087 Posts: 504
edited November 2016 in Daz Studio Discussion
Skin poke through - Genesis 3 female - Interstellar armor  http://www.daz3d.com/interstellar-patrol-for-genesis-3-females
I have tried V7 and Gen 3 female, same problem.Whenever character squats skin pokes through in crotch area where upper leg meets lower abdomen.
The smoothing don't seem to apply with G3 characters. Is there a tutor or information how to fix.
Post edited by rampart_1576840087 on
  • SimonJMSimonJM Posts: 6,094
    Easiest way may be to hide that portion of the G3F
  • SimonJM- Yes for sure.  I was thinking along the lines of modifying the clothing.
    I need to move on this project, so for sure I'll just hide those character parts and move on.
    Thank you,
    Not seeing it here. I will say that I get poke through as the G3F's joint are mived, but it resolves when the movement stops.
    342 x 386 - 60K
  • Quickest fix, Since her legs are not seen... Hide them.
    Quick fix is to throw a D-Former ball on each upper leg, and shrink her leg a bit there...
    Or, put them on the pants-bones, and move the pants further away from the skin.
    Only takes a slight adjustment to do that. I assume that there is a morph which is altered, with no equal correction on the outfit.
  • TheKDTheKD Posts: 2,711
    Usually those issues only happen for me with HD morphs on. It would be cool if there was some sort of automatic switch that would turn off HD when covered with clothes lol. Probably too complicated to make happen though.
