Products appear pitch black/covered in darkness
Hi All,
A couple of times, I've selected products to use in Daz Studio and they appear pitch black/covered in darkness.  I've tried re-booting the computer, re-booting the program, re-loading the product, and shining lights at the products, but they continue to appear completely black.  Has this happened to anyone else?  Is there something I should do to remedy the problem?  Any guidance would be appreciated.  Thanks!
Cheers,
Roel
    Can you give a specific example?
    If you hit render, does it stay black?
  • Hi MJC -- thanks for checking in.  In terms of specific examples, I've experienced this most recently with "Toon Rocket and Moonscape" (http://www.daz3d.com/toon-rocket-and-moonscape) and "Parthenon Bank" (http://www.daz3d.com/parthenon-bank).  I don't hit render, because I just import my images into Photoshop through the Photoshop 3d Bridge.
  • scorpioscorpio Posts: 8,533
    It could be that they use shaders that only appear when rendered.
  • Hi Scorpio,
    Thanks for the insight.  This makes sense. Is there anything I can do from my end to reverse that? Or does it mean I need that I need to render the products?
    rrutorres said:
    Hi Scorpio,
    Yes...if it's the shaders, which is very likely, then yes you will need to render them.
  • Roger that.  Thanks mjc and scorpio.  I appreciate the clarification!  Cheers!
