Dangling alpha mapped hair
SonofbelmontSonofbelmont Posts: 147
Hi
I have some hair which is comprised of modelled strips of polgons and alpha maps that I'd like to make dangle and sway automatically with a characters movement. Can this be done somehow in Carrara 8.5? and if so then how?
So far I've been playing with softbody but it just kind of crumbles up when the head is tilted upwards so I don't know if it will really do what I want
any help would be appreciated
  • 3DAGE3DAGE Posts: 3,315
    HI Son of Belmont :)
    What you're making is Polygon hair,.
    What you're trying to make is dynamic hair.
    You could create Morph targets in the model,. then you can animate those morphs.
    You could add bones and weight mapping and then animate the bones,. and perhaps use some physics to effect the bone motion.
    Carrara can create Dynamic hair, which can be "simulated" to calculate the hair physics in an animation (pic)
    1000 x 750 - 187K
  • SonofbelmontSonofbelmont Posts: 147
    edited November 2012
    Thanks for your response 3DAGE
    I've heard of Carrara's Dynamic hair and it looks pretty cool however I'm going for a very cartoon look so I think polygon hair is my only option
    What you mentioned about using physics to effect bone motion sounds interesting, how would that be done?
    Post edited by Sonofbelmont on
  • gaffer2gaffer2 Posts: 67
    you might want to set the thicknes on the dynamic hair to large use the clump feature it may also worl for you if you can make yuor charictor smaller so the hair strands look more ropey . just an idea not knowing your set up or desire
    What about an IK chain?
    You probably only need a few pieces to be physics-enabled (bangs, maybe a ponytail or cowlick) but not all of it (depending on length and gender of the character - since everyone knows girl hair blows around constantly while man hair sits still and holds it's style with natural male hair gel... it's genetic in animationland no matter how long the hair is suppose to be...)
    HI :)
    I think Holly's suggestion is a great one,. you don't need all the hair to be dynamic,. and as Gaffer suggested,. making large dynamic hair could also be a good option,
    The physics based option would be the hardest method to make, and get right. since it's a simulation.
    usimg morphs or bones will give you real control over what's happening..
    Dimension Theory did an example video where he used bones, tracking physics sphere's to drive the animation of a plane to make it like cloth,.. but I think that was before Bullet softbody.
    You can now use Bullet Softbody, and Softbody attach to make some sections of the hair "dynamic", See example clip
    https://dl.dropbox.com/u/7907045/soft_hair_test.mov
    Note that this is a "proof of concept" rather than a "Best example",. :)
    I LOVE this pic, Lighting is great... like an album cover!
    maybe a little attention at the sideburns, those hairs seem a little broom like...?
    Amazing image...
    Thanks Holly :)
    as a mock album cover it has it's limit's,.. but,.. is this close...
    1000 x 750 - 218K
    3DAGE said:
    Thanks Holly :)
    LOLOL! :coolsmile:
