Comfused if I have to have something called Carrrara to use these elite skins for Victoria 4?
I bought a bundle for Victoria 4.2 and it had 3 elite skins-textures not sure what they are called. Anyway, everything I bought installed but these 4 items and it says I need Bryce and carrara. Is this really necessary, and if so, how do I install them?
Thank you!!
  • SimonJMSimonJM Posts: 6,101
    Those specific items require Bryce (for the Chalet) and Carrara for the V4 Elite textures.  I think that the products also include the Cararra and Bryce files to enable them to be used in those products as well as in Daz Studio, so you have no real need for either Bryce or Carrara.
  • They support multiple applications - Poser, Carrara and DS for the Elite texture sets. You need install only the files for the versions you will use.
  • Note that there's a difference between "must have these items to use this item" and "this item will also work with these items". It isn't always easy to tell which is meant; if you're not sure, posting a query here should clear things up quickly.
  • Ah, good, so they just include those textures for the other programs if you have them. Thank you!!
