Broken glass in iray
So... a year ago, I hired a friend to do this picture: http://fav.me/d9ga13l
It's a very cool picture.
The thing is, LQ did the picture in 3Delight and, recently, we were wondering if there was a product or method for achieving similar effects with iray. Everything we've tried so far has ended up being, ironically, too transparent. It makes the glass either invisible in the render, or else a mere shadow instead of a sharp, jagged mess. Any ideas?
  • DaWaterRatDaWaterRat Posts: 2,887
    edited November 2016
    Are you using the Iray glass presets?  If not I'd reccomend trying one of those first.
    Make sure Cutout opacity is at 1, and you'll want to set Thin Walled to off and Abbe to at least 55 (these are taken from the glass dispersive preset that comes with the Iray shaders)
    I've attached a quick, not even complete render of the Glass, Solid, Clear dispersive rainbow preset as an example.
    1050 x 894 - 2M
    Post edited by DaWaterRat on
  • Thanks! I'll give it a shot. :)
  • Silent WinterSilent Winter Posts: 3,965
    http://www.daz3d.com/colored-and-broken-glass-iray-shaders
    ^This one's pretty good.  Used it in this image:
    http://www.daz3d.com/gallery/#images/243941/
    But it has lots more colours and about six different broken/shattered glass effects.
    (In the image, the actual shattered pieces are a blender explosion, but you can see the texture on the model)
    Edit: Finally got to see the image you mean (was at work before and didn't look as DA said something about 'mature content' - can't imagine what from the image).
    So yeah - just use one of the iray glass shaders on the pieces - make sure 'thin walled' is off in surface tab (should be if you use the default shaders) - and have stuff in the scene to refract/reflect
    Post edited by Silent Winter on
  • prixatprixat Posts: 1,628
    That black ceiling can be made to work in 3Delight but Iray will need something actually there to reflect.
  • BeeMKayBeeMKay Posts: 7,019
    You can also use the crystal shader from this set: http://www.daz3d.com/iray-frozen-brothers-for-genesis-3-male
  • AllenArtAllenArt Posts: 7,176
    I've noticed in Iray that if there's no background that glass can go transparent in some places/views. Make sure your scene is entirely surrounded with something to reflect other than the neverending transparency of the default blank scene background.
    Laurie
    Post edited by AllenArt on
  • FistyFisty Posts: 3,416
    Yes.. big problem with gems too..  you can also just make sure there is a backdrop in the environment tab, even if it's just a grey color (I use 70/70/70 usually)
    With Iray...if using the Iray Glass (solid if the mesh has thickness), there shouldn't be any need to do anything, if using the dome with an hdri in it.  The first is 'Draw Dome: Off' and the second is with it on.  No need for anything else.
    If using Scene Only, then yes...you'll need something for it to interact with/reflect.
    512 x 640 - 58K
    512 x 640 - 233K
    Post edited by mjc1016 on
    Yes, I found that out too ;) Very strange. LOL
    Laurie
  • macleanmaclean Posts: 2,438
    I've put a couple of broken glass items in products (in Everyday Junk / Everyday Display Cases), and my method is to give the edges their own material - glass_edge. That allows you to use different settings to get the effect of broken glass.
    You can probably use the Geometry Editor to apply a new material to the edges.
  • ^great tip, thanks :)
  • MarcCCTxMarcCCTx Posts: 948
    Thanks for thos glass settings. They really enhanced the look of the glass.
    After
    Before
    987 x 740 - 418K
    987 x 740 - 549K
    Post edited by MarcCCTx on
  • srieschsriesch Posts: 4,243
    Where/what was the broken glass called in Everyday Display Cases?
    Er...... color me embarrassed, I just looked and I can't see any in Display Cases. I could have sworn there was something, but I'm wrong. Sorry about that.
