Aiko 7 & Kenji 7
nonesuch00
Hey,
On Aiko 7 (and Kenji 7 I think when I buy that model) there is a Shaping slider in the Shaping tab listed under Head to change Genesis 3 Female to an Anime shape. I was wanting however only to change the eyes to be more anime sized and shaped but not 100%. Is there are way to do that using the Kenji 7 and Aiko 7 models Shaping presets?
Thanks.
I purchased the face and body morphs for Gen3 Females and I have that ability, but I did not see anything specifically related to Aiko 7 that would do it. I do not own Kenji 7
OK, thanks. I have those too, maybe I can unlock the limits to do what I want. I will try unhiding morphs.
This is about as big as G3F eyes can get with standard morphs. Unlocking doesn't seem to offer an additional margin.
It's certainly possible that There is a trick I don't know.
OK, thanks. I will use the 'inner almond' and 'outer almond' to make them round. Maybe I will need to unlock the almond sliders too.
The Eyes Size dial isn't actually a morph on its own, it's a controller for a large number of other morphs; unlocking the controller won't unlock the dependent dials. Have a look at the Parameter Settings dialog for Eyes Size — you'd have to tweak the limits for all of these, which is very definitely non-trivial.
Doh! Forgot to check there. Unchecking limits in Eye Size let's you get eyes outside of the sockets. Definitely Creepy. One can quickly see why it's a linked/limited controller.
