Rigged the bones to a new created body morph, clothes dont follow..
I created a new full body morph. It worked, I watched a tutorial to rerig the bones to the new morph. It worked. But in the process, dunno how and when, the clothes and hair don't fit the model anymore when I dial the new morph. :( And I cant go back.. I saved the scene
Post edited by TheCediz on
Is AutoFollow checked when you go to the Parameter Settings for the morph - click the gear on the slider and select Parameter Settings from the menu.
That simple??? ... let check this out right miaw.
Yes it is checked :/
Is it failing with all clothing and hair?
Yes everything. No problems with the other traditional morphs .. Tell me if you need any information
Thanks anyways
I'm not at all sure what could cause that. I don't think it would be the issue, but is the morph's Type set to Modifier/Shape in Parameter Settings?
It is yes. Don't you think it has to do with the rigging bones thing?? I also tried to ERC freeze the skeleton for this morph but that didn't go well either, This is after I abandonned the project of doing that that I noticed clothes and all weren't fitting anymore.
Edit: I know the clothes were following the morph before I rerig the bones. So it is between the rerig and the ERC freeze that the trouble happened.
You know what, I'm gonna rerig the bones to the g3f base model, delete the morph and reimport it into morph loader pro.
It kinda pain me to do it, but whatever, don't lose more time over that. I'll probably come back soon or later for another question ;)
thanks Richard!
Well Well Well... I fixed and reloaded the morphs. Everything was good. I saved and guess what? If I close Daz and come back, the problem comes back too. Again the clothes are not following the body morph I loaded. But it did just fine before I close Daz! . .. Any idea left ? :S
Ah, this is an issue
kitakoredaz has been experiencing, which support has had trouble reproducing. Please report it, mentioning that he has also reported it, and perhaps that will enable the devs to get to the bottom of it.Oookkk, is it in Help>contact us>help center>submit a request ??? Well that's what I just did anyways.
Aannndd, do you know if this problem was with any morph he was creating or only one? Was he using GoZ or morph loader pro?
Yes, that is the way to report a bug. He discusses his experience here http://www.daz3d.com/forums/discussion/106056/auto-follow-morph-can-not-work-about-genesis3-with-4-9-3-117-too
Yess. Thank you!. I just figured an hour ago that for the problem to go away, I needed to save the morphs asset. I'm happy I can now bypass this bug.
Please report it, even so.
I've done that already. Thx for your time
Ah, sorry - thank you.
