Save scenes with less 31 frames
Imago
There's a way to save a scene that contains less than 31 frames?
I did some short animations of 15 frames and saved them as scenes to be used later, but when I load the scene, the Frames amount goes automatically to 31!
I tried creating a startup scene with less frames, but DAZ keeps putting 31 frames anyway!
I woudl like to save the time to check and correct that...
Suggestions?
I don't know of any way to change the Daz default minimum of 31 frames, but you can always manually adjust the total number of frames to anything you like after loading the scene. Bit of a pain - but just takes a few seconds to correct.
Thanks Tring01, your suggestion is good... But it's exactly what I wanted to avoid!
Well, it seems to be one more thing I have to learn!
