Panoramic 360 renders
skybluerobskybluerob Posts: 27
Hello,
Does anyone know how to do 360 Panoramic renders in Carrara?
Thanks.
Rob.
  • RoguePilotRoguePilot Posts: 239
    edited November 2012
    Hi,
    I'm assuming you want a spherical panorama.
    Insert a spherical camera,
    rotate it 90 degrees on the X-axis so it's facing along the ground plane,
    move it above the ground if necessary,
    set your aspect ratio in the render room (usually about 2 x 1, try to get as high a resolution as you can if you're using it as a background),
    select the spherical camera on the output tab,
    and hit render.
    Of course it helps to have a 360 degree scene to render.
    Post edited by RoguePilot on
