Maybe a silly question but as im new here he goes...
IKtorIKtor Posts: 44
How do we make a separate object like in image if we wish to make it only that part? Thxs
  • de3ande3an Posts: 915
    Select the parts that you want.
    Choose Edit/Copy.
    Go back to the Assemble room and insert a new Vertex object.
    Edit/Paste the copied object into the vertex modeler window.
  • 3DAGE3DAGE Posts: 3,315
    HI Trialg
    Welcome :)
    There's no silly questions,. just simple answers :)
    With the item selected, go to Edit /Copy.
    Jump back into the scene,.. Assembly room.
    Go to Insert, Vertex object,. and once you're in there,. Edit / Paste.
    The object you copied will be pasted into the same position as it was when you copied it.
    but it's now a completely separate model.
    Another method is to use the option in the Assembly room to Edit / Split object,. which will take a multi poly-mesh object and create an object from each separate poly-mesh.
    this isn't always the most ideal solution if you want to just work one one part of a model in the vertex modeller, you can select and Hide the parts you don't want to work on, and then make them visible again, when you're done.
    Hope that makes sense :)
  • ManStanManStan Posts: 0
    I have an even simpler answer http://www.daz3d.com/products/hexagon/hexagon-what-is-hexagon
    :coolsmile:
  • IKtorIKtor Posts: 44
    Thanks Desan and 3Dage lol Manstan I know that answer :) but i cant hold so many crashes it turns my mind crazy even I like a lot Hexagon :)
