Another question about GenX for Genesis
I've been practicing with the GenX plugin; now I want to delete what I've done and that nothing appears when loading a new Genesis; how can I do this?
"data/DAZ 3D/Genesis/Base/Morphs" - that's where the morph files for Genesis are stored, any made by GenX will be in there, so you need to find them and delete the DSF files.
Be CAREFUL! when you call up any figure you've saved that has those morphs you're about to delete applied, you will get an error message.
As far as I know, the morph is not actually loaded till it's in use, just the dial... (someone correct me if I'm wrong, please)
Thank you for your answers.
I'm still on an old version of DS4 and I delete morphs and didnt get an error when loading old scene files with the Genesis.
If this is true for the newer DS4.5 I'll loose a lot of work.
I did it once in DS4 with a figure I created using a morph I deleted. I don't think I got an error message, but the figure was not what I had saved.
