Egypt outfits for G3M
HeraHera Posts: 1,964
Hi!
Are there any Egypt outfits for G3M to be found somewhere? Something like this?
  • XenomorphineXenomorphine Posts: 2,421
    The Genesis costume is also compatible with all the 'Pharaohs Of The Sun' M3 texture add-ons.
  • zombietaggerungzombietaggerung Posts: 3,930
    edited October 2016
    Just a heads up, on the Anunnaki outfit, for some weird reason the left bracer doesn't seem to accept shaders or textures that are iray compatible. The right one does just fine but the left one renders as if it still has 3dl shaders on it. It's really weird, since this vendor's stuff is usually perfect and I've never had any trouble with their other stuff in iray. All the rest of the outfit is fine though.
    500 x 400 - 30K
    Post edited by zombietaggerung on
  • FSMCDesignsFSMCDesigns Posts: 12,855
    That is because the material zones are wacked. the right bracer has seperate ones for the various parts, the left bracer is all in one which is really odd. They both will take IRAY shaders, just not specific materials for specific areas.
  • Just a heads up, on the Anunnaki outfit, for some weird reason the left bracer doesn't seem to accept shaders or textures that are iray compatible. The right one does just fine but the left one renders as if it still has 3dl shaders on it. It's really weird, since this vendor's stuff is usually perfect and I've never had any trouble with their other stuff in iray. All the rest of the outfit is fine though.
    That's unfortunate, since I could export it has an obj and fix that in blender, but then I'd lose the rigging once I dumped it back into DAZ. The only thing I could do in DAZ was use the geometry editor to assign the appropriate surfaces the correct materials, but that won't save as a material preset. I could save it as a scene subset though.
    Ah well.
  • Aave NainenAave Nainen Posts: 1,108
    Ah well.
    You can use transfer utility to transfer rigging from the original after re-importing the fixed obj.  Easiest would probably be using "replace source with target"
  • caravellecaravelle Posts: 2,752
    Hera said:
    Hi!
    I would appreciate new Egyptian male outfits very much, since the 'Pharaos of the Sun' for Genesis Male have some imperfections. E.g. the belt area doesn't fit if you take the M3 textures who leave the chest uncovered. But I would like to have them more authentic - no Hollywood or Carnival styles... ;-)
    caravelle said:
    Hera said:
    Hi!
    Perhaps you could post a few images of the more authentic version you are hoping for?
