how to remove/turn off smoothing in ds4.8?
MistaraMistara Posts: 38,675
hi
i'd like to try removing smoothing from g3m, save as a character(?), then test if he still crashes carrara.
i think was on the top menu somewhere, squint squint
thanks
    Smoothing is applied via the surface which is not something that gets transfered when exported.
    A smoothing modifier which affects the mesh is used on the clothes and hair to avoid poke throughs and do layered clothing.  It is not applied to G3M by default.
    edited October 2016
    i think it has a special smoothing for the face bones posing.
    g3 hair and clothes, atleast the ones i tried, come into carrara without crashing.
    i'm surmizing is something with the face.
    it's not the face bones themselves, since collada export and import doesnt crash carrara. i can see all the face bones and bone shadows.
    the mesh itself loads okay.
    assuming the clothes use same weightmapping tech as the g3m figure, so i think we could eliminate the wm as the crash trigger.
    iray shaders dont crash.
    as sherloch holmes said, elinimate the possible ... what remains,
    must be it
    Post edited by Mistara on
