Is there anyway to use Visual Style Shaders and pwToon together?
in The Commons
I posted this earlier, but I think I posted it in the wrong place so I'll post here. I'd like to be able to use pwToon and Visual Style Shaders together but I'm not sure if that's possible and if so, how would you do it?
I guess it depends on what you're trying to achieve.
Easiest way might be to do it as two renders then layer it in GIMP / PS
I don't know, but I will comment about the layering... I've had a lot of fun with doing multiple PWToon passes and layering/compositing. Sometimes I combine Iray + PWToon, too!
Having a 'juicy' layer of color or shading that you can filter, then gently add in some outlines or light shaded/line layers ... fun stuff!
(Check out my DA account in sig for some recent examples)
yes me too, not those products but other renderstyles in Carrara and Hitfilm Blend filters in my case as do animation.
Render passes and compositing are what the pros do afterall.
