Adding to Cart…
Great new releases today! If these will work well in DS, then you may soon become one of my favorite PAs, Tom! :)))
With too many purchases recently I'll look forward to the DS releases and a hopefully better supply of hobby money. The latest releases look great, but a question/request. Poser went through some scale changes that made life difficult in the past. There are also scale consistency issues with a few other vendor's otherwise fine groupings. I hope a DS release is at the appropriate and consistent scale.
Problem solved with the help of Daz tech support. Blocks 3-4 load into DS without materials. To add them, load the block, select both parts of it in the Scene Tab, select all the surfaces in the Surface Tab, go to Content Directory and navigate to Poser Formats/My DAZ 3D Library/Materials/Dreamland Models/03 Low Poly Three and click on the Default icon. That loads all the materials in their proper places. Save that as a Support Asset/Scene Asset and it will now load with textures.
The same procedure also works for the Movie Sets: River Front. Here's an updated view of one of my previous renders showing Low Poly Block 3 (on the right) with it's textures, the roads, sidewalks, and grass using the default textures, and the Summer Sky texture applied to the skydome. Much better. So yes, this set can definitely be used in Daz Studio with a little bit of texture mapping and reducing the specular settings if some surfaces are too bright..
It comes with DAZ 4.8 and above by default. Under Shaders there is an Iray section, and the !IrayUberBase shader, if you apply it, will auto-convert stuff to default Iray settings. I usually ctrl-click and tell it to ignore images so it retains the old diffuse image jpegs and whatnot.
My understanding is, if you do not do this, but just hit render with 3DL surfaces, Iray will do this conversion automatically as the first step of the render. But I always apply the Iray shader anyway to convert things over. This then allows me to tweak surfaces if I want to.
Thank You for enlightening me.... Ray
Hey just started reading, and can't stop. Really good stuff!
Hi All,
I am sorry I have not been posting answers to all of you, but I am working very hard to finish,
Movie Sets: City Block 01
It is a full City Block with lots of detail.
Did not realize how much work it would be to reply to each post in here.
I simply do not have the time to keep up with it.
I am looking at the thread but most likely will not be responding to all the posts.
Thank you all for your support in here. It means a lot to me!
Here is another Poser render of the Poser version.
Regards, Tom
Understandable, check in when you can.
Hey I don't remember seeing the hot air balloon over on Rendo! Nice balloon!
Thank you. :-)
Tom
Welllllcom Tom, Got one set bookmarked now. I could use a few in Carrara 8.5 Pro. Nice modeling!
I started a thread (Exploring Dreamland in DAZ Studio) in Art Studio to capture my learnings about using the Poser only Dreamland Products in Daz Studio. I'm working my way through various features and explain how to adapt where needed. So far I discuss creating categories for easy access, adding default textures, using the camera and pose presets, and using some of the River Front parameter dials. My next post will be about using the power poles.
Thanks for your help!
Tom
What do you mean by functional?
Tom
Oh, okay. That is in a set with no interiors.
Would have to model the building over again to do so.
Sorry.
Thanks for your interest is my products Barefoot.
Tom
I tried out the River Front weather prop in Daz Studio. Instructions can be found here.
Nice!
I like the RDNA Atmospherics Lightning, It's an actual object that you can apply an iray light shader to.
And Vol.1 is free right now. Just got it earlier today.
Also check out RDNA Atmospherics - Fog Vol 1 RDNA Atmospherics - Rain Vol 2 also free. Cool I should be able to use all 3 in Carrara even if I need to adjust a few shader settings.
