Disable drag parenting?
I've been getting annoying when I click on one thing in a scene that it will sometime accidentally get dragged and parented to another thing when I don'd want it to. Is there a way to turn of drag parenting in the scene tab?
  • ScavengerScavenger Posts: 2,674
    Drag parenting doesn't work consistently for me...it does for you?
  • No it doesn't sometimes i just click on one object in the scene tab and I move my mouse ever so slightly (I don't even notice it) And the object just gets parented to another object. That's why I want to know if you can disable drag parenting in the scene tab.
  • FSMCDesignsFSMCDesigns Posts: 12,846
    Sounds like you need to calibrate or replace your mouse, never have had that happen on my end, then again I use a trackball which allows for finer movement than a regular mouse'
    in poser, holding shift key keeps you locked on to your current selection
    been desiring similar in DS
    when i try to drag a handle, often i end up catching the floor or something
