Skin Swapping
If I want to put Ysabeu 6's skin on Mynx's body (her previous one got all torn up!) would this product make that possible?
http://www.daz3d.com/legacy-uvs-for-genesis-3-victoria-6
  • FSMCDesignsFSMCDesigns Posts: 12,855
    yes, as long as Ysabeu uses the default G2F texture UVs and not her own special UV mapping as some of the addon characters do.
  • exstarsisexstarsis Posts: 2,128
    How do I discover that?
  • JOdelJOdel Posts: 6,322
    She's a DAZ original character base, so she almost certainly has her own UV set. Her add-on characters (that shipped with her bundles) are probably built off the G3F's base, though.
    You select a surface (Face does nicely) then in the Surfaces tab, look for UV Set.  Ysabeu looks like she uses the G2F 'base' UV set, so the V6 UVs won't work,
  • CybersoxCybersox Posts: 9,733
    She uses the default g2f textures.
    Sorry, Meant G2F.
