HELP!
ArhainArt
I am thinking my lap top is incompatible with IRay engine. See attached. Image on left is before rendering, right is after. Only happens when rendering in IRay. 3Delight works fine.
Your anti-virus application has deletd a needed file - freeimage.dll. Kaspersky does this, as does one of the others. If you can, restore the file from the quarantine/vault area, otherwise reinstall DS, then make sure the file is marked as safe so it doesn't get removed again.
Thanks. In my case it is ZoneAlarm.
