DS Default Reset Remotely?
xyer0
in The Commons
I was rendering reference headshots of single characters at default settings, and I closed and opened Daz. My next render had the same settings as before, but the render started out washed out like the headlamp had been quadupled in intensity. I cannot find any noticeable difference in the render settings. It seems that the default has been changed, but I changed nothing. Has anyone ever experienced this, and might it be related to the recent website maintenance?
Daz Studio 4.9.2.70, Windows 10
Studio software won't change unless you installed an update. Settings changes, those are done by the user, whether intentional or not.
Are you using a camera?
If you are using one of the 'views', like perspective, settings/position won't be saved.
Also, if are starting fresh, instead from a saved scene, it's likely that the headlamp was On.
Thanks for responding. But I didn't reset my default (and I merely opened a New scene without making any settings changes); so, something else must be afoot. I'll work around it.
I was using a camera, and I was also intentionally using the headlamp, as that is the objective standard I use for all my character reference mugshots (Daz Original Base and Raiya skins do quite well with the headlamp). Thanks for your help. I guess for the time being I'll work from saved scenes and delete the files to start anew.
