Look-At-The-Camera script to animate characters - For Daz Studio 1 2 3 4
mCasualmCasual Posts: 4,607
edited May 2012 in Freebies
download and manual :
https://sites.google.com/site/mcasualsdazscripts2/mcjlookatthecamera
Introduction
This script for Daz Studio will take care of posing the head, and optionally, the neck, chest, abdomen and hip, so that the face faces the current camera.
This script was suggested by Daz Forums member Tugpsx
Use
Select a figure's head.
launch the script
it looks like this
https://sites.google.com/site/mcasualsdazscripts2/mcjlookatthecamera/ui2.png?attredirects=0
select the playrange to be processed.
Select the bones (other than the head ) that participate in the twisting of the body required to bring the face to face the camera.
click on the Doit buttom
done
Post edited by mCasual on
  • mCasualmCasual Posts: 4,607
    edited May 2012
    brand new demonstration video for the script right here !
    oops changed it to http://www.youtube.com/watch?v=NhFhNMEwJWA
    300 x 160 - 363K
    600 x 400 - 41K
  • DigiDotzDigiDotz Posts: 515
    thanks for this! attaching a camera to anything you want the character to track works well too ;-)
  • SyndarylSyndaryl Posts: 521
    Wanted to post another Thank you! This is a very very helpful little script!
  • waningmoonwaningmoon Posts: 30
    thanks for the script!
    regards,
    waningmoon
  • carol leecarol lee Posts: 14
    Thanks for the script
    welcome
    recently i added a similar script but for the eyes
    https://sites.google.com/site/mcasualsdazscripts4/mcjstareatthecam
    https://www.youtube.com/watch?v=n7EDW5WxpT8
    480 x 270 - 1M
  • IsazformsIsazforms Posts: 210
    Thaks¡¡¡ So I have a question. When the figure (i use g2f) is in bed, the head orientation doesnt works correctly. Please help
  • MilosGulanMilosGulan Posts: 1,988
    Wow, it looks great. I will have to try it :)
    edited February 2015
    the script doesn't orient the head using a very complicated process
    it' works about okay for standing poses but for not for horizontal poses
    if you temporarily Z-Rotate the camera so that your figure, as seen from that camera looks like it's standing up
    then Look-At-The-Camera script will work
    once that's done, you un-rotate the camera
    or you could parent a camera to your render camera, we'll call it the laydown camera
    you z-rotate the lay-down camera until the figure as seen from the layDowncamera looks like it's standing up
    you make the lay-down camera the current viewcam
    and run the script
    1280 x 720 - 423K
    1280 x 720 - 356K
  • I see this thread is quite old and talks about applying the script to Genesis2. I'm trying to use it for Genesis3 and it doesn't behave well. In my animation (a walk cycle) the head wobbles a bit and then looks in all sorts of directions! If I try running it repeatedly on a single frame, the head keeps looking around as if she can't see the camera, changing each time I run it. The animation is in the timeline, not in Animate2.
    Should it work on Genesis3, (or 8)? Any suggestions? If it's only for Genesis2 I guess I could use mcjCopyPoseAnim (which I've found very good, by the way) but it would be a lot more work.
    Thanks for any help!
  • Hi mCasual !
    Im a totally rookie in DAZ,Just found this perfect Software 2 weeks ago LOL
    and now im trying to make some movies
    my promblem is :The script only make effect at the first frame...
    For example, in a very simple 5 seconds movie ,I chose the first frame and the last frame to setting the same camera position and angle ,because I want the camera always look at the
    same place,then at the first frame I use the script to setting the character's head direction,when I click that "Do It" botton I can see all frames got a pin on it,I thought It's done,
    But when I play the movie,the character's head dirction is only right at the first frame,in other frames,that head never look at the camera....LOL
    I may need a step-by-step PDF or video to make it clear...
  • functionfunction Posts: 285
    edited April 2024
    recently I spent 2 days to modify this mcjLookAtTheCamera script, make it suitable for Genesis 1 to 9.
    Now the job is done, works well, but, I only modified the static part (current frame 0) for static figure, didn't touch animation part because I didn't do animation.
    This modification version is to salute Mr. mCasual for his greatest script mcjLookAtTheCamera.
    To use it, just check the 'Current Frame Only : 0', and choose those participates, then Do it. Can undo.
    zip
    zip
    mcjLookAtTheCamera_G1-G9.zip
    8K
    Post edited by function on
  • atoxicatoxic Posts: 155
    Thanks - as usual.
    You did all those scripts. I appreciate your contribution.
    edited April 2024
    i can put your version along with my old version
    and maybe merge the 2 functionalities and add something to improve the angles
    when i want precision, i z-scale the eyeballs 3000% and i reorient the 10ft-long-eyeball-sticks until they are in the camera frame,
    but i dont like z-scaling my actresses' eyeballs ... because they wouldn't like looking weird like that
    but if i fix that issue with mcjLookAtThe camera i would improve my actresses life :)
    edited April 2024
    i double posted and dont see a delete so
    i'll add an mcjLookAtTheCamera pic
    note that there exists a script named mcjStareAtTheCamera which does for eteballs what it does for the head orientation
    edited April 2024
    oh and after using mcjLookAtTheCamera YOU Want mcjTorsionSpreader which can spread the torsion of the head joint to the chest and abdomen nodes and hip, but i rarely put the hip in the selection of joints that "share the torsion"
    https://sites.google.com/site/mcasualsdazscripts8/mcjtorsionspreader
    Thanks again
    Oh that's great, welcome back, and please merge it. Thanks! yes
  • RGUSRGUS Posts: 15
    This awesome, but is there a G9 version, it doesn't have eyeballs.
  • Silver DolphinSilver Dolphin Posts: 1,640
    Very nice all your stuff is usefull. Thank you
