Real Eyebrows for Genesis 3 Female
in The Commons
Hello everyone
I follow the tutorial until I have to apply the shape then I keep getting
"Duplicate IDs where found while reading the file see the log for more details" and then "Failed to access eyebrow node".
Where can i find that log ? How can I get it to work ?
Thx
...the log file should be in Users/App Data/Roaming/Daz3D/Studio4 (log.txt).
Sounds possibly like an installation error. Did you use the DIM or manually install it?
I have, it and didn't encounter any issues.
Help -> Troubleshooting -> View Log will open the error log. Search for the error to determine the offending product file. You'll need this to correct it. I don't know what interaction there might be if it's a Connect download so YMMV.
found this
Duplicate id "Real Eyebrows for G3F" found in file "/data/iWave/Real Eyebrows for Genesis 3 Female/Real Eyebrows for G3F_53944.dsf"
Duplicate id "Real Eyebrows for G3F_53944" found in file "/data/iWave/Real Eyebrows for Genesis 3 Female/Real Eyebrows for G3F_53944.dsf"
Duplicate id "hip" found in file "/data/iWave/Real Eyebrows for Genesis 3 Female/Real Eyebrows for G3F_53944.dsf"
Duplicate id "pelvis" found in file "/data/iWave/Real Eyebrows for Genesis 3 Female/Real Eyebrows for G3F_53944.dsf"
and this
WARNING: fileinput\dzassetdaz.cpp(1859): Could not find geometry definition: /data/iWave/Real%20Eyebrows%20for%20Genesis%203%20Female//Real%20Eyebrows%20for%20G3F_53944.dsf#Real%20Eyebrows%20for%20G3F.
WARNING: fileinput\dzassetdaz.cpp(1303): Failed to create uv set!
WARNING: fileinput\dzassetdaz.cpp(4484): Could not find geometry for the material instance.m_uri.
WARNING: fileinput\dzassetdaz.cpp(1322): Failed to create material!
I will try the duplicate program or reinstall
thx
According to a comment yesterday, the update has issues.
Thx :)
My ticket had a reply saying the DIM version is working, I need to check now that the log-in issues should be fixed.
Yes, the DIM install works.
If you're looking for some fun with the eyebrows, load a set, copy it, mess with the copy's curl/frizz/length/etc, and you have heavier eyebrows that look ace.
I got it to work by uninstalling everything in the install manager. That eliminated the duplicate files.
Then I uninstalled real eybrows in connect and installed it again in the install manager.
thx for the help
