Real Eyebrows for Genesis 3 Female
Hello everyone
I follow the tutorial until I have to apply the shape then I keep getting
"Duplicate IDs where found while reading the file see the log for more details" and then "Failed to access eyebrow node".
Where can i find that log ? How can I get it to work ?
Thx
1917 x 1040 - 850K
  • kyoto kidkyoto kid Posts: 42,399
    ...the log file should be in Users/App Data/Roaming/Daz3D/Studio4  (log.txt).
    Sounds possibly like an installation error.  Did you use the DIM or manually install it?
    I have, it and didn't encounter any issues.
  • EsemwyEsemwy Posts: 578
    Help -> Troubleshooting -> View Log will open the error log. Search for the error to determine the offending product file. You'll need this to correct it. I don't know what interaction there might be if it's a Connect download so YMMV.
  • found this
    Duplicate id "Real Eyebrows for G3F" found in file "/data/iWave/Real Eyebrows for Genesis 3 Female/Real Eyebrows for G3F_53944.dsf"
    Duplicate id "Real Eyebrows for G3F_53944" found in file "/data/iWave/Real Eyebrows for Genesis 3 Female/Real Eyebrows for G3F_53944.dsf"
    Duplicate id "hip" found in file "/data/iWave/Real Eyebrows for Genesis 3 Female/Real Eyebrows for G3F_53944.dsf"
    Duplicate id "pelvis" found in file "/data/iWave/Real Eyebrows for Genesis 3 Female/Real Eyebrows for G3F_53944.dsf"
    and this
    WARNING: fileinput\dzassetdaz.cpp(1859): Could not find geometry definition: /data/iWave/Real%20Eyebrows%20for%20Genesis%203%20Female//Real%20Eyebrows%20for%20G3F_53944.dsf#Real%20Eyebrows%20for%20G3F.
    WARNING: fileinput\dzassetdaz.cpp(1303): Failed to create uv set!
    WARNING: fileinput\dzassetdaz.cpp(4484): Could not find geometry for the material instance.m_uri.
    WARNING: fileinput\dzassetdaz.cpp(1322): Failed to create material!
    I will try the duplicate program or reinstall
    thx
  • JimbowJimbow Posts: 557
    According to a comment yesterday, the update has issues.
    Thx :)
  • My ticket had a reply saying the DIM version is working, I need to check now that the log-in issues should be fixed.
  • Yes, the DIM install works.
    If you're looking for some fun with the eyebrows, load a set, copy it, mess with the copy's curl/frizz/length/etc, and you have heavier eyebrows that look ace.
  • I got it to work by uninstalling everything in the install manager. That eliminated the duplicate files.
    Then I uninstalled real eybrows in connect and installed it again in the install manager.
    thx for the help
