Carrara Academy for Light of Heaven
1810121314
  • atticanneatticanne Posts: 3,009
    Did you ever figure this out, Jacob?
  • VIArtsVIArts Posts: 1,526
    Nope, but I trashed my model. I tried to make t three times and it kept looking like trash!
  • 3DAGE3DAGE Posts: 3,311
    HI Jacob :)
    What’s the best way to make a string tied through a hole?
    good question,..
    it depends on what you want to show the viewer,.
    If you want a close up of the knot, then you'd need a reasonably detailed model, ,perhaps with a frayed end (dynamic hair)
    if it's more distant, you could use a simpler model, or a displacement map.
    If you want an object swinging from that rope, like a noose, then it's more complex.
    Carrara's "Bullet" soft-body physics can be used for flexible objects like a rope, but the option for internal pressure isn't working correctly, so it's probably easier, and quicker, to create a long cylinder, with many sections,.. and add a line of bones to it, so you can bend the rope whatever way you want.
    I posted this question over in the C8.5 beta thread too. Does Carrara have a log that we can look at for troubleshooting?
  • stitlownstitlown Posts: 309
    I know this is the right place with 3-Dage active. Hi again mate. And I did chuckle at your comment quite a few back about how your funny bone got to dissolve.
    To business. I'm ex-vue and in vue you could make something endlessly repeat (as in set up a perpetual tweener. Interface wise it was similar to the tweener interface here but had an additional check box saying (I paraphrase) "and keep on keeping on after the end keyframe")
    I'm doing bunches of grass (about 75,000 of the little darlings across the whole scene, not much of which is in camera at any time - created by about 20 grass bunches surface replicated at various scales) which gently sway in the breeze. The oscillator tweener only does 20 oscillations.
    Is there any way in Carrara to get a similar outcome, ie specify one cycle of tweening then get Carrara to repeat it ad infinitum?
    Will also be useful for my gently heat-hazing and refracting sun disc as it sinks slowly into the golden West.
    Thanks in advance for any good suggestions.
    Lx
    Wendy mentioned surface replicators in Skype and I would like to know more about them. What are they? How do I do them?
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,264
    lol! and after telling Anne to post here, would like to know why this thread did not show up seaching my posts!!!
  • JaderailJaderail Posts: 0
    Your Handle Changed so the Posts are lost in Limbo? Just another Error? Not a clue? Pick one.
    Another question I have is about going 100% Genesis. What about props, etc? Do I just ditch morphs I have for V4, V3, M4, David, etc?
    edited December 2012
    Part one, more advanced to come
    ask questions
    1901 x 1041 - 510K
    1928 x 1067 - 409K
    1930 x 1066 - 416K
    1918 x 1076 - 441K
    1909 x 1069 - 366K
    part two
    distribution map
    513 x 512 - 29K
    1920 x 1080 - 257K
    1914 x 1076 - 514K
    1906 x 1057 - 483K
    1895 x 1035 - 325K
    map inverted, smaller sized irises heaps more of them in replicator
    1920 x 1080 - 1M
    1916 x 1069 - 781K
    Thanks, Wendy. Hope I get some time to try this later today.
    Part 1, screen 3: What is the hot spot?
    If I make a mistake, how do I undo it?
    Part 2, screen 4: Mine screen doesn't look like yours.
    edited January 2013
    1) the hot point is the pivot point the object transforms around, it is usually dead centre you want it at base of object for replication
    press caps lock and moving transform arrow will shift it without moving the object.
    2) edit up top, undo
    3) what is different?
    screen capture perhaps?
    image 4 is a render
    I haven't given up yet. I need to practice the hot spot some more.
    I could see undo, but it was grayed out. I need to keep better notes so I'll know what I was trying to undo. I resorted to closing the document without saving. No problem, gives me more practice. Each time I'm a little faster at it and get further along.
    quick physics 101 for noobs
    1902 x 1029 - 416K
    366 x 220 - 27K
    1908 x 1033 - 396K
    noob hair
    1907 x 1009 - 390K
    651 x 526 - 99K
    1916 x 1042 - 394K
    450 x 408 - 45K
    1915 x 1033 - 410K
    edited January 2013
    drape and simulate
    1920 x 1080 - 661K
    1915 x 1027 - 417K
    edited January 2013
    400 x 225 - 442K
  • BlumBlumShubBlumBlumShub Posts: 1,108
    Oh my GOD, Wendy, I've never seen hairier balls than that.
    Say, if i set two keyframes and set their tweener to Drscrete and I wantr it to do that same thing for 2 seconds, do i make a keyframe at the 2 second mark and set the tweener to Oscilate?
    flashy test
    640 x 480 - 454K
    I'm very impressed, Jacob. Give me 3 or 4 years and maybe I can do that too.
    Anne, that's not even hard. It's as easy as flicking a switch up and down as the clock ticks.
    edited February 2013
    one shadowcatcher tutorial coming up for LOH
    need to bump to next page
    so it is not a bump, here is a render of LOH
    1214 x 2000 - 311K
    he wants to do a valentine render
    he is hot and ready
    2000 x 2000 - 409K
    waiting for his date
    1000 x 600 - 87K
