HELP HELP
MohanMohan Posts: 0
Hi can anyone please HELP!
I have created a new top both in cararra and hexagon. I first export a male genesis figure as an obj file and shape the top to fit in both programs. When I export it back to DAZ and it fits the genesis figure I go through the fitting routine as per tutorials on youtube.
That is I go to edit, geometry, convert to sub D assets, transfer, utility, scource, genisis figure, target, my top. But the top becomes bigger and is way above my genesis figure. When I move the figure the top moves with it. I have tried scale and translate but the will not move or scale the top to fit the figure. Please help
regards
Michael
  • Richard HaseltineRichard Haseltine Posts: 109,456
    You need to set the Source Shape to Genesis male, and then expand the morph option button and check reverse Source Shape from target option.
  • MohanMohan Posts: 0
    Thank You
    I just tried that but the object now shrinks and ends up between his legs, and I can't move or scale it
    Also when I start my DAZ 4.5 PRO the only plug with a serial number listed is animate 2 lite how do I enter other plugin serial numbers (eg CCT)
    Regards
    Michael
    The CCT is part of DS4 Pro, so it's controlled by that serial number - and is already working if you have the Transfer utility.
    Did you scale or otherwise adjust the OBJ after you imported it and before you ran the Transfer utility?
    when I imported the obj and it asks "convert to DAZ Studio" I tried Cararra 1 unit =1in but the import is tiny. so i used Silo 1 unit=10cm which gives a reasonable size. I then move & scale it to fot the Genesis figure and go through the transfer routine, but it gets attached to the left foot
    Michael
    If you modelled around an exported Genesis you should import using the same setting as you used for the Genesis export. However, if you can't remember that another option is to export the modified clothing and then reimport it, taking care to use the same preset each time. The Transfer Utility works on the default item, ignoring any scaling or other adjustments.
