AutoFit dialog - Loose Tight listed twice
3dOutlaw3dOutlaw Posts: 2,481
edited November 2012 in Daz Studio Discussion
Loading a clothing object from V4 onto Genesis, auto-fit kicks in, after choosing the style in V4, there is a Loose and Tight options. In mine, there is 2 of each (i.e. Loose, Loose, Tight, Tight)
I was having a crash error with V4 Bodysuit (saving a scene), and it ended up being because I used the first "Tight"...
Anyone else have 2 listings of each, and if so, know what the difference is?
Post edited by 3dOutlaw on
  • Richard HaseltineRichard Haseltine Posts: 109,523
    Have you ended up with two isntallations of the Genesis files - in particular \Data\DAZ 3D\Genesis\Base\Projection Templates?
    Maybe so. There is a tight.dsf and a tight.duf in one of them, for example.
    The .dsf are left-overs from the DS 4.0 content. They should have been uninstalled. (Though I am surprised to find .duf files in the \Data folder - I expected them all to be .dsf, with .duf reserved for the user files.) I imagine the duplicates are causing the application to get confused, and so to crash - try removing the .dsf files that duplicate the .duf files in that folder.
