Selecting (or not having to select) the UV
Sometimes when I apply materials to G1 I have to change the uv to the correct matching value.  Other times I don't.  Does it just depend on the product with some products applying automatically and others not, or am I missing something important?
  • nonesuch00nonesuch00 Posts: 18,762
    edited September 2016
    I'm not sure 100% but I think it depends on whether or not the current loaded model was created for the texture set you have just loaded. I use textures sets on models intended for another models and when I load those texture sets I must change the UV set of the target model for it to look correct.
    Post edited by nonesuch00 on
  • Materials Presets should usually set the UV set, but if you apply a Poser-format PZ2 file (or MC6) then any UV changes will need to be set manually.
  • srieschsriesch Posts: 4,243
    Ok, thanks.
    For the ones that apply automatically, is there any reason for the average user (me) to even care what UV is being used?
    The reason I ask is right now I have all materials usable by Genesis1 marked or categorized into subfolders based on the UV so I know which UV to set the material to after applying it.  But for the materials that automatically apply to G1 regardless of whether they were for V4, S5, etc. then I think I don't care, and I can just dump these materials all into the same folder which will make things easier to find and categorize.  But before I start trashing this old system I just want to make sure there aren't any other reasons to track this info so I don't loose a large quantity of work if it turns out later there was still some reason to keep track of this.
  • As long as you have the UV set you won't care which is being used unless:
    • you want to use an overlay product, in which case it needs to be using the same UV set
    • you want to use it on another figure, in which case you need to make sure that other figure has the required UV set (Genesis 2 Female has the Victoria 5 UVs, but a lot of Genesis characters use the Victoria 4 UVs, so that can be an issue without add-ons).
    there may be other situations, but those are the two that come to mind.
    Helpful, thanks.
