N.G.S. Anagenessis II - Revolution [Commercial]
Dimension-ZDimension-Z Posts: 352
N.G.S. Anagenessis 2 Available Now!
http://www.daz3d.com/n-g-s-anagenessis-2-revolution
For any misunderstooding:
http://www.daz3d.com/n-g-s-anagenessis-for-genesis-3
N.G.S. Anagenessis for Genesis 3 is my previous release.
______________________________________________________
Two Completely Different Products!
UPDATE NOTE (11.5.2016):
For users that purchased my product, a small update fix will be released this week:
1. For UV Set (After this update you won't need to change UV Set manually).
2. Removing Map From Glossy Layered Weight for Dark Skins (After this update you won't need to remove it manually)
3. Glossy Color Fix from 0.30 to 0.35
Thnx For Your Comprehension
Dimension-Z
Freebie Script for Non-Genesis/Prop Figures:
https://www.dropbox.com/s/t4k1zybc3b54its/NGS 2 Freebie Script.zip?dl=0
Tip:
Tip for NGS2:
If you had big pores with only one diffuse,
just add micro map as a layered image on top of top coat bump!
- Subtractive Blend Mode
- Opacity 60%
Post edited by Dimension-Z on
«13456743
  • pdspds Posts: 593
    Intriguing...
    Will this be sold as a separate product or some sort of add-on to the original N.G.S. Anagenessis product? Will you be offering some sort of incentive pricing for people who already bought the original?
  • pds said:
    Intriguing...
    People who bought it, won't have the same deal with a new one! Maybe as add-on for those who bought it without offer and low price for them who bought it with offer. This is absolutely the truth!
    But I'm thinking of it as a seperate product, because it works only with one diffuse map. It's like a new skin shading system!
    And this was done only with presets! It's Amazing!
  • As an immediate addict of the first set, am definitely interested in this one as well.  Intrigued to see how only one diffuse map can be wrapped around all the different UV maps...
  • @Dimension-Z:
    Appriciated if you are thinking about a promo pricing for buyers of the first Anagenessis (like me). Maybe use those fancy orange banners I've had a couple of times recently. Should be no problem for DAZ people to set it in a way giving buyers of version 1 an extra  % off just for Anagenessis II.
  • Do you make any other adjustments to get the natural "blotchiness" of the skin. What is the technique? I have every shader set and every light set and I seldom get results like this.
  • Is this still being developed?
  • InkyInky Posts: 33
    New Days are Coming for Skin Shading & Texturing!
    One month after My first N.G.S Anagenessis Skin Shader Presets I'm working on this new one:
    OK. What we have here?
    N.G.S. Anagenessis II with ONLY ONE Diffuse Map!!
    Yes, That's right! Only ONE Diffuse Map!!
    You know what does this mean...?
    V1/V2/V3/V4/V5/V6/V7 & M1/M2/M3/M4/M5/M6/M7 with one diffuse map!
    Hey there sir!
    First let me say that I love your product and cant praise you enough on how natural everything looks. Great job!
    I was curious, this is sort of unrelated to your product, but what character/body shape did you use for this promo???
    http://www.daz3d.com/media/catalog/product/cache/1/image/9df78eab33525d08d6e5fb8d27136e95/0/0/00-main-ngs-anagenessis-for-genesis-3-daz3d.jpg
    I love the muscle definition on the stomach and waist especially. for the life of me I just cant find a body that matches in the shop.
    Thanks in advance for your time and again.... great job!
    -Inky
  • CybersoxCybersox Posts: 9,346
    Hey there sir!
    -Inky
    On his DevArt page he says that it's http://www.daz3d.com/clara-for-genesis-3-female-s
    Apprently, it's been sent or will soon be sent to Daz for testing. The promo images on the artist's deviant page are incredible.
  • peteVaultpeteVault Posts: 308
    edited October 2016
    Ohhh...that's why I haven't seen anything...thank you for your information.  I made my way over to his site...this thing is a paradigm...for sure.
    Post edited by peteVault on
    Hopin' and bumpin'
  • pete.c44 said:
    Hopin' and bumpin'
    In a week or so. Thank you!
    Thank you....I am really anxious to get this product....can you tell?
  • xyer0xyer0 Posts: 6,353
    Me too!
  • and me!
    xyer0 said:
    Me too!
    xyer0 said:
    Me too!
    edited October 2016
    Will there be a Generation 4 and Generation 3 preset? I did not see the thumbnails on your YouTube video. I ask since you mentioned, "V1/V2/V3/V4/V5/V6/V7 & M1/M2/M3/M4/M5/M6/M7 with one diffuse map!"
    Post edited by xyer0 on
    Its for all Genesi figures, from V4-M4 to V7-M7
    V4 and Genesis have the same surfaces.
    So, do we click the Genesis 1 button when we use V4/M4? Pardon me if that's a dumb question.
    Exactly. No problem asking me.
  • jcbunnjcbunn Posts: 271
    what happened to V1/V2/V3 ?
    It works with manual work. Like I said is for all Genesis figures plus V4. It does work with one diffuse map, but V1-V3 have different surface names. So it wont work automatically.
    But with one diffuse it works manual, if you change surface names like Genesis' names.
  • RedzRedz Posts: 1,459
    Can you please explain exactly what you mean by 'one diffuse map'? Perhaps it's a language issue, but I am having difficulty understanding what this product actually is. I watched the video, but was still a bit unclear. Is this an Iray über shader skin preset that only uses the original character's diffuse textures (more than one), discarding normal, bump, displacement etc maps? Or are you replacing the diffuse maps with one unique diffuse map? The results look very good. If just like to be clearer about what I might be buying. Thanks.
    Its exactly iRay Uber Shader Skin preset system, that automatically loads diffuse map of the original character to specific places (more than one). Its discarding speculars and bumps, not normals or displacements.
    Any other question I'm here to help you
    Thank you too.
    Thank you too.
    Appreciate the clarification, thanks :)
    Since the names for some Genesis 1 surfaces are different from Genesis 2 and Genesis 3, and likewise between Genesis 2 and Genesis 3, I assume you had to set them yourself to make the presets. Did you leave out the V3 preset because relatively few people use her?
    You have nothing to do with Genesis/V4, Genesis 2 and Genesis 3. It will convert them to N.G.S.2 automatically. Only Victoria 1, 2, 3 need manually renaming to surfaces. Very old with low resolution textures. Thnx to all!
    By the way, are you still working Victoria 3?
    I use her sometimes in the mid-ground or as a mannequin. I have some hi-res textures and high fashion clothes that I use with her. But I don't know if I want to rename all the textures just for that. I have all the conversion tools, but I'm not motivated to change yet. This may do it.
  • Dimension-ZDimension-Z Posts: 352
    edited November 2016
    As I said N.G.S. 2 has One Click Solution only for All Genesis Figures (Including V4 & M4). Any other Non-Genesis Figure needs manually to be applied.
    Although I will give to all people a guide & a freebie manual system after product's releasing for easier applying on Non-Genesis Figures.
    Thank you
    Dimension-Z
    Thank you too.
    You're most welcome.
    Note:
    N.G.S 2 is not just a shader preset that uses only one diffuse map.
    The presets parameters are so thoughtful made, that you'll take the best skin result for any human or non-human figure, with any kind of light or environment.
    After all, you should have seen the results of all my promos or not promos images without any postwork.
    Thank you
    Dimension-Z
