DAZ3D and Mixamo animation problem
Hi from France,
I used to export mixamo animations (skeleton, BVH) into DAZ3D characters. All was perfect. But now DAZ's characters don't follow most of the animations anymore, especially when there are acrobatic animations. For instance, during a backflip animation the characters stay stuck in the air instead of going back to the ground. Why such a difference ?
Could you help me solve this strange phenomenon?
Hi those Mixamo motions are created with a rig that has
a proper IK system for foot contact with the floor in jumping/landing motions
Daz studio does not.
Since BVH uses the hip as the root mover for the entire figure
this causes problems as the hip to feet IK chain is not preserved when the mixamo Rig is exported to BVH.
Hi Wolf359 :-)
thanks for your help.
I"ll try the aniblocks anim which are more adapted
Can you specify the Mixamo motion you use? And the figure you're exporting from, and also the figure you importing to.
The rigging on the currently available Mixamo characters isn't unfortunately fully compatible for DAZ characters anymore. Genesis 3 is the worst, for it's node layout is incompatible to Mixamo's auto-rigging system.
Is there a workaround at all?
Apologies, new to these forums, specifically trying to solve same problem.
Someone somewhere else said to try importing BVH to G2 figures, then exporting that BHV out of Daz, then re-importing onto G3. By putting onto G2 first and then exportin,g it's Daz friendly when re-importing back into G3, or something?
