TerraDome 2 and Poser 11 Pro
Does TerraDome 2 work with Poser 11 Pro or did I just did I mistake getting TerraDome 2?
  • It should work perfectly in firefly, superfly...... It *might* be ok, there is an internal conversion process on the shaders, but I would say no in superfly
  • TSasha SmithTSasha Smith Posts: 27,428
    Will terradome 3 for poser work with superfly?
  • fixmypcmikefixmypcmike Posts: 19,709
    Terradome 3 is for DS.
    edited August 2016
    oh yeah, oops my bad.
    Yeah it does not work well with SuperFly.  Thanks but I thought I loaded one scene but it looks like a different scene.  That could be user error though
    edit I wanted to load the Hidden Lake scene
    1085 x 861 - 1M
    Post edited by TSasha Smith on
  • Yeah this is another scene, but if that one loads, I don't see why any of them would have an issue in Superfly. You have all of the elements in there.
    That was a firefly render if I recall correctly
  • QuietrobQuietrob Posts: 361
    To remove confusion.
    This is Terradome 2.  It is done with Superfly settings set on Medium.  I can get rid of the white specs on the mountain by using a higher setting but I wanted to get this done quickly.  As you can see Terradome does work in Poser 11 using Superfly.
    1912 x 897 - 232K
