TerraDome 2 and Poser 11 Pro
Xyetzt
in The Commons
Does TerraDome 2 work with Poser 11 Pro or did I just did I mistake getting TerraDome 2?
It should work perfectly in firefly, superfly...... It *might* be ok, there is an internal conversion process on the shaders, but I would say no in superfly
Will terradome 3 for poser work with superfly?
Terradome 3 is for DS.
oh yeah, oops my bad.
Yeah it does not work well with SuperFly. Thanks but I thought I loaded one scene but it looks like a different scene. That could be user error though
edit I wanted to load the Hidden Lake scene
Yeah this is another scene, but if that one loads, I don't see why any of them would have an issue in Superfly. You have all of the elements in there.
That was a firefly render if I recall correctly
To remove confusion.
This is Terradome 2. It is done with Superfly settings set on Medium. I can get rid of the white specs on the mountain by using a higher setting but I wanted to get this done quickly. As you can see Terradome does work in Poser 11 using Superfly.
