Bed creasing
Is there a known way to "crease" a matress under the pression of g3 sitting/laying on top of it without using a bed that has the morphs built in?
  • LeanaLeana Posts: 12,855
    In DS you could use a dformer to alter the shape.
  • as long as there was enough mesh resolutuion - if the top of the matress was a single polygon you'd be stuck.
  • kaotkblisskaotkbliss Posts: 2,914
    I often select the bed, go to edit -> object -> geometry -> apply smoothing modifier, then have the bed collide with the figure
