Gilikshe renders: playing with shaders
124»
  • AJ2112AJ2112 Posts: 1,417
    Unique, different and very cool shader renders, tutorial would be appreciated *hint*, Lol, have fun, keep up the work :-)
  • almahiedraalmahiedra Posts: 1,373
    Thannnnkkkksss!!!
    No much time (busy busy) + horrible english prevent me from doing a tutotrial just now, but like I said in a past post, mosaic shader should be the ideal case to do a tutorial, when I get time and patience to fight with english I will try with one about mosaic shader.
    Good sources to begin with shader builder are:
    http://www.sharecg.com/v/66014/browse/3/PDF-Tutorial/DAZ-4.5-Shader-Builder-Tutorial-MK-Gooch-Shader and books about Renderman like Apodaca's Advanced RenderMan: Creating CGI for Motion Pictures.
    Some tests after a failing secundary HD (2 teras bye! bye!) and a test of shader colors and layers with Iray testsphere.
    Simplicity 1: Angel of Silica
    Simplicity 2: Princess Pride
    600 x 600 - 341K
    1200 x 800 - 992K
    1800 x 1200 - 503K
  • algovincianalgovincian Posts: 2,687
    These are great, gilikshe! Glad to see you posting your work again. Sorry to hear about your drive failure . . .
    - Greg
    - Greg
    Thanks.
    The evil HD waits until I installed and customized all my purchased content, then, one day after it died.
    Awesome renders, would love to learn this method :-)
    Thanks awesomefb.
    Playing with glossy again.
  • KharmaKharma Posts: 3,214
    Wonderful shaders GiGi...I would like to learn how to make shaders, any possibility of posting the steps to make a simple shader?  I have looked at shader mixer and shader builder but am completely lost even with the minimum of documentation I can find for the newest version of DS.
    edited August 2015
    Yes, this is in my schedule because I think already is time to this and the free tutorial link in sharecg is broken, but it isn't immediately, when I end a research article for my job then I will work in  shader builder mini tutorial for a simple shader with interesting tips.
    Post edited by almahiedra on
    Thanks for considering doing this, I will look forward to a tutorial. :)
  • Wow, these are very nice images. Very very nice images.
  • Joe.CotterJoe.Cotter Posts: 3,362
    edited October 2015
    GiGi, you might be interested in 'Freestyle' in Blender, its made to do this style of rendering.
    Post edited by Joe.Cotter on
    Thanks Sphinx! :)
    Yes, and it is one of the points to think in adopt Blender like a tool in the future. I'm trying to evaluate if the effort to achieve a good knowledge of blender worth in rendering and cloth creation. Just now I see this after following your link: http://wiki.blender.org/index.php/Dev:Ref/Release_Notes/2.71/Freestyle and words: script, outline, python look very attractive.
    Gigi, Freestyle has been updated in the latest version of Blender (2.76) There is a quick 3 minute video showing the new features here if you are interested.
    Thanks, I have an eye in blender since now. In another thread you said something about renderman and blender, but I couldn't understand if this was a fact or a possibility and what it mean exactly.
    It ends up I missed the fact that the free license is for non commercial use, but here's a video describing it: Using Pixar's RenderMan in Blender
    Note, Freestyle is part of the Blender Internal render engine, not Cycles or Renderman, so to use Freestyle, the render engine needs to be set to Blender Internal.
    Thanks for the info. No good if it is for non commercial. Can I suppose that there is a payed license for commercial use?
    For the full Renderman yes, but it's not cheep. Blender (and Freestyle) is free for commercial work.
    edited September 2016
    Shader Builder Mini Tutorial
    0.- Intro/Introducción
    Goal: Create a simple surface shader to understand SB basic use.
    Meta: Crear un surface shader básico para entender el uso básico de SB.
    Warning:
    * These are my basic steps to work in shader builder. I don't know if these are good or efficient writing code practices to handle variables and others.
    * I can't find in DS4 online guide the SB section so I could be using wrong terms in some point.  Found!
    * This is an anti-spaguetti approach : one only macro calling several individual external functions by lines of codes. I only use other blocks when these are image blocks.
    1.- Shader Builder Tab / Pestaña de Shader Builder
    a) SB Documentation/ Documentación de SB
    Begin read here: http://docs.daz3d.com/doku.php/artzone/pub/software/shaderbuilder/start
    Read RIspec 3.2 from page 106 (page 117 in the pdf)
    b) Find SB / Encontrando SB
    c) SB Parts / Partes de SB
    1. Catalog
      1. Left side: Shader Categories
      2. Right side: List of shader, DAZ implemented and user shaders
    2. Designer (no visible when shaders aren't selected)
    Catalog:
    Shader Categories: Surface, Light, Displacement, Volume and Imager
    Shader List - New shader
    Bug: For me, DS4.9 is closed when click in accept after create a name for new shader
    2.- Shader
    Selecting a shader shows Designer tab for this shader
    Double click in shader shows tabs associated to Designer tab, only for selected shader: Block Network, Shader Code and Log
    So, now SB parts are:
    1. Catalog
    2. Designer
      1. Block Network
        1. Block Repository
        2. Shader window
          1. Menu: Compile Shader, Save Network and others
          2. User Parameters (Input, left side)
          3. Shader parameters (Output, right side)
          4. Several blocks, functions or macros.
      2. Shader Code (it can't be modified, shows RSL code version of all macros and functions)
      3. Log (It can't be modified, shows the list of warnings and errors in shaders)
    Block Network
    Shader code
    Log, you will be happy when it is empty, shader hasn't problems
    325 x 697 - 95K
    928 x 819 - 103K
    223 x 124 - 5K
    756 x 166 - 33K
    930 x 333 - 59K
    931 x 521 - 90K
    719 x 364 - 40K
    512 x 473 - 25K
    230 x 216 - 8K
    660 x 415 - 51K
    3.- Function Blocks / Bloques de Funciones
    4.- Macro Blocks / Bloques de Macros
    5.- Work in Network Window / Trabajando en la ventada de red
    a)
    reserv2
    reserv4
    reserv5
