Show Us Your Bryce Renders! Part 9
Adding to Cart…
Actually, the slider will only take it back to 1 but you can type in 0.1 and get it less.... Though I'm not sure how much difference that will make.
Helpful hint: I had one scene where I set the haze density to 0.2, but the value changes back to some default every time you go into the sky lab, so you have to manually change it back every time. (Took me a while to figure out why my haze kept changing seemingly at random.) As I figured I would have a hard time remembering this, I actually named my folder "ruined city scout (must set haze density to 0.2 every time skylab is entered)". The issue only happened with very small values below a certain point (don't remember what value.)
Haze grows with distance, it can be increased with Color Perspective. Strategies to reduce the effect of haze: downsize the scene, don't use Color Perspective, move camera nearer to scene and increase FOV, keep Base Height of haze at 0; or switch off haze and use a cube with a volume material that can be better controlled.
Well I've kept my head down modelling stuff. Some stuffs seeming to be easier to make than others... though I can't tell if that is a limitation of myself or the software. Making things that look "organic" I find particuarly challenging. So here's a mix up of thigns lit with one of Horo's Sunless HDRI's http://www.daz3d.com/bryce-7-1-pro-sunless-hdri-skies
There are Bryce generated stones, using Bryce materials and rendered in Bryce (obviously I hope). First image is lit with direct HDRI lighting, second via TA (which took a couple of days - due to leaf transparency).
Ivy generator was used for the ivy. And the rest was made in Modo using a variety of approaches.
I've seen a lot of modeller folk say they have to use different programs for "organic" vs hard surface, even though each program is capable of both. So you're not alone in finding a software's way of doing some things easier than it does others. I think you could conquer all in Modo if you keep at it, but it may be worth trying some other programs to see if they gel better with you for organics. Mechano vs plasticine, etc. Anyways, I'd be over the moon if I'd made your progress.
I could also do with a brain transfer of your practical handyman skills right now. I have acquired new (1960s) house and am in the process of ripping out the old (shudder) - (no, seriously, shudder) ready for adding in the new. I'm OK with destroying things, but then...
Good advice from everyone with haze, I have try to reduce it at 0,4 but there's no significant difference with the first render (I have use crop render to do so). Another thing to consider is that I have no patience anymore to re-render the entire picture.
@David : beautiful render, far from Bryce standard! Did you use Bryce terrain to model this rocks walls or is that modo modelling? A very nice effect with ivy too, it fits nicely in the decor. Bryce stones are sometime giving hard polygon edge, I usually export them to wings3D to apply subdivision filter, then importing them back to Bryce.
Here's another render from me. It's a mountain scene inspire by a terragen render. I have try to put as much as xfrog pine trees I can (about 20000). To do that, I have first reduce the polygon count of the trees with meshlab. File size at 560 mb and memory usage ar 3,3 gb. It took 7 days to render at 36 rays/pixel.
David - very nice terrain, Ivy-Generator and Modo work. I somehow prefer the IBL, it's a bit more crisp.
c-ram - nice to see this render finished, Marco. Great work on the sky and clouds, as well.
Another triple stacked terrain from our Hi-Res Terrains set 1. The sky is an HDRI but not a photographed one. I took the Bryce default terrain and rendered it as distant mask, faked it into a true HDRI, then cheated to make it a spherical panorama. It lights the scene and gives the clouds, the sun enhances the light and adds the shadows. To brighten up some black spots ignored by the HDRI and sun light, a dome light was added. The lake has a radial under water with ssquare falloff and just above it another radial with the inverted Bollard IES mask from David. The dome light has 256 lights, the HDRI quality 128, the sun soft shadows, rendering premium with 16 rpp and normal priority only took 15 minutes in this size.
@Horo: Great materials and phantastic sky
@c-ram: Outstanding. Simply the fact, that you have use 20000 trees is nearly beyond my imagination
@David: Great work. I especially like the atmosphere in the doorway/tunnel
I tried out a new tool in DAZ3D to pose a character. Light comes from a spot light. To enlight the dark areas I used a very dim distant light. First I tried out a HDRI but render time was very long (several hours) and the result rather disappointing. With the distant light render time melt down approximatly 17 minutes (TA with 36 rpp)
Electro-Elvis - thank you. Nice dance render. Not all HDRIs are suited for every scene. To light dark areas, you can use an uniform HDRI (one without prominent lights) or a dome light; often you can disable shadow casting for such jobs and this will speed up renders considerably.
Horo –Nice little town in the Blue bubbles, Glowing Pond is another great render.
Dave- lovely space scene.
David – nice to see a render from you, cool modeling in Modo, like the mysterious atmosphere beyond the gate.
C-ram – another magnificent render.
Electro-elvis – nice render, but the model’s right hand looks a bit flat, could be due to the shadows
A simple render inspired by Dave’s Pylon render on page 74, Spacebones Pylon model and a Sunless Hdri Sky by Horo
A man who can fix a leak and fit a sink will never want for friends with leaks and unfitted sinks. Yes well, if you live close enough I could be coaxed into lending a hand, I will fix things for food and beer.
Yes, well I have had a trial of Z-brush which looks very good, but I fear my poor brain will pop if I try to learn too many new thigns at once.
@C-ram, aye I've been inspired many times by Terragen renders, you've done a great job there, somehow Terragen has something special in terms of lighting but I found the scenes otherwise a bit artistically sterile, your scenes have more character.
@Horo, great sky and lighting, wonderfully atmospheric. You have achieved and got away with a high contrast scene. If I saw this sky I'd be looking for somewhere to shelter.
@Electro-Elvis, thank you, character work is always tricky, you do well to attempt such things. Dark shadows and strong light with skin - a tricky combination.
@Mermaid, thank you. My kind of render that is, I do like to see these pylons, I don't know why some people think they are eyesores.
A quick render of the sort of shape that lends itself to my skills with Modo. Rendered using http://www.daz3d.com/bryce-7-pro-50-metals-the-heating-room-set for light and materials.
@ Horo : thank you! Well, finally there's no modification compare to the previous image I've send to you. Good stacked terrains, I really like the textures and the way they are lit by the light.
@ Electro elvis : thanks! yes, a lot of trees but as I have already say, I'm tired with xfrox pines. They are not good looking compare to recent production like speedtree models.. you've done another nice character picture, I like the pose and the light.
@ Mermaid : thank you, nice pylon render.
@ David : terragen is a pure landscape generator and its render engine is far better than Bryce even more if we are talking about the fourth version coming soon. But, it's terragen and it's unable to produce Bryce touch.. I have work with it by the past and made some nice pictures but I quickly return back to Bryce because I was unable to impose my style to the software. However, terragen pictures are sometime a good source of inspiration, that's true. Oh and nice modo modelling! Your skill is growing up!
More great renders from everyone. Good to know I'm still inspiring people Mermaid
Electro Elvis: As Horo says, turn off shadows in IBL tab. Also set quality to the lowest and HDRI shouldn't impact on render time much at all. There are so many different ways of introducing some natural ambient light it's a proper minefield... You got a great result though.
My latest... A freebie model I picked up years ago... This one took nearly 2 hours just to smooth the mesh. Lit only by two radial lights.
And one of the same bike with materials and lighting changed to make it more reflective.
i did a render of that bike a while ago myself :)
Mermaid - thank you. Pylon render looks photo-realistic, good POV.
David - thank you. Great drill render.
c-ram - thank you.
Dave - great bike renders.
Tim82 - this bike also looks great monochrome.
Yes, Tim, the bike looks great with all it's original materials on too and your render is very well done. Re doing the materials in Bryce isn't easy as the model only has about 5 components so all the engine and handlebar parts etc have to be the same material.
As David and Horo's High Res Terrain sets were on sale today (Sets 2 to 4 are 60% discount) I spent my pocket money on them this week.
Once again the sheer amount of stuff you get for your money is incredible (even at full price these are well worth the investment).
I can see I'm going to have months of fun (and frustration in the DTE) customising the presets.... Here's my first render with this set.
@ Dave, yeah i thought it was a pity that the bike had limited parts, i kinda cheated a bit and imported the OBJ into blender and separated the hole thing right down to individual nuts and bolts
Ooof, it's Sunday morning here and you're using the 'B' word Tim....
lol!
hahaha i know i know!
...it has its uses at times but bryce is my one true 3D love
David – Thanks, very nice model, lighting and materials.
C-ram – Thanks
Dave – Thanks, lots of inspiration here but very few “I can do that” ones. Thanks for mentioning you used Spacebone’s model. Both the bike renders are great – the 2nd is my fav. Love the FrozenWasteland.
Tim –nice bike render awesome especially the lighting.
Horo – thanks
Another simple render - Sunset
Being away for only a week makes you miss out on a lot here!
Thanks for the commenta on my gulls. And great space, scene, bike and other renders!
Love that one, Mermaid...all it's missing is some camels on the horizon.
Of the below work, was thinking of Absinthe (the drink) the other day, and as the word sounded like the word Absentia (the horror film), I put a kind of dark theme to the work. Title, of course, has got to be 'Absinthe-tia'
One of Horo's & David's Fantastic Skies was used.
Jay
Jay - thanks. Great render, awesome lighting and colors.
Very nice Jay, all that's missing is the green fairy.
Exploring the high res terrains sets from David and Horo (as mentioned in my previous post).
Heh he
Love the grand canyon one...shadows are perfect.
Cheers, Mermaid.
Jay
@Jamahoney: Wonderful scene for indicating the (earlier) risks of absinth.
@Dave Savage: Great terrains. I like the one with the ruins best.
Yes, yes, Hansmar...'the piano has been drinking' (YouTube link to Tom Waites song)
Jay
Dave - wow! great use of the terrains. I really like what you've done with them.
Mermaid - very peaceful scene.
Jamahoney - ah, Absinth, also known here as Fee Verte (green fairy). Not overly healthy for the brain in larger quantities. Though tea made from the plant absynth can heal even stomach ulcers. It is terribly bitter but one can get used to it. It grows here and I've always a stock of dried one around. Great render and the skull really fits.
