Vascularity HD for Genesis 3 (Commercial)
13»
  • Is there a way to control the morphs for the whole body? Without going through each part one by one?
  • Zev0Zev0 Posts: 7,123
    edited August 2016
    What you can do is dial them all up to your liking and save it as a shaping preset that can be loaded on your figures at any time. When doing this just select the vascularity morphs. Now you have a one click preset. Make sure you de-select everything first and then only tick the vascularity morph folder. I didn't create a full body option because there is just way too much variety of styles and my preference wouldn't be liked by some, so I leave it to the user. It is why the morphs are all split up.
    501 x 863 - 52K
    Post edited by Zev0 on
  • StingerStinger Posts: 331
    These vascularity morphs don't seem to work well with iray.  Can you offer any tips?  Are you planning an update?
  • FSMCDesignsFSMCDesigns Posts: 12,858
    No need for an update, they work great with Iray. Make sure you turn up the resolution/subdivion on the figure for best effect.
    edited June 2018
    There's nothing wrong with the morphs, it's the way Iray rendering works with HD levels of detail. A freshly loaded base G3 figure has Resolution set at High, SubDiv Level at 1, and Render Subdiv Level at 2. That's barely enough for HD morphs to be visible, and they definitely won't look right. You won't see them properly unless the SubDiv Level is bumped up to 3 or 4 (some morphs might need an even higher setting). Note that this doesn't just apply to Vascularity, it applies to any HD morph, e.g. the base expressions for the G8 figures.
    Post edited by SpottedKitty on
    Thanks FSMCDesigns and SpottedKitty.  I will give it a try.
    edited June 2018
    Some test renders didn't come out too bad. Thanks again FSMCDesigns and SpottedKitty.
    Post edited by Stinger on
