hey can someone help me , i am trying to get oily skin for genesis 2 female and 3
lasagnaman
in The Commons
does anyone know how to do that , like when your at a beach and it shows that oily skin look
Iray or 3Delight render engine?
Purchaseable products for Iray:
For 3DL:
hi iam looking to do it without the wet skin
is there anyway i can do that
thanks
like this pic for iray
In Iray, you can easily do it yourself. Here's different methods with images: http://www.daz3d.com/forums/discussion/59766/#Comment_872147
Of the purchable shaders, this one might be fitting best: http://www.daz3d.com/hdri-optimized-skin-hair-shaders
It looks like these three products also give a oily or wet skin look (I don't own any of them so I can't attest to how well they work):
http://www.daz3d.com/light-it-up-iray-lights
http://www.daz3d.com/n-g-s-anagenessis-for-genesis-3
Select the character; then under surfaces select skin or skin/lips/nails (your choice and depends what you require).
Scroll down to Top Coat Weight; this will need to be above zero; you may need to alter it, try initially 0.5.
Top Coat Rougness might be better with a lower figure.
There will be a drop down with Fresnel in it (likely), change it to reflection. The setting below will be Reflectivity after changing, before if set to Fresnel it would be Top Coat IOR.
Reflectivity, try 0.5; mess about till you get what you're after.
hey ty so much, ill try that , thanks again
