Strange spots on clothes
Hi guys,
I got some strange spots on the clothes (German SS Black Uniform WWII) of my model, both in preview and in render.
Does anybody had the same issue? Any suggestion?
Thanks you as usual!!
    This usually because the clothing has an outer and inner mesh that are colliding when smoothed or posed.
  • donatellomiragedonatellomirage Posts: 13
    edited August 2016
    Hi jestmart, thank you for your relpy.
    Dou you know how to solve this problem?
    Post edited by donatellomirage on
  • nicsttnicstt Posts: 11,715
    See if you can select the part you want, and turn its opacity to zero in the surfaces tab; it may not be noticeable in you render, even if parts are visible elsewhere because they need to be, due to the camera angle you have. Use the surfaces selection tool to select the part you wish to make 'invisible'.
