Strange spots on clothes
donatellomirage
Hi guys,
I got some strange spots on the clothes (German SS Black Uniform WWII) of my model, both in preview and in render.
Does anybody had the same issue? Any suggestion?
Thanks you as usual!!
1125 x 761 - 608K
This usually because the clothing has an outer and inner mesh that are colliding when smoothed or posed.
Hi jestmart, thank you for your relpy.
Dou you know how to solve this problem?
See if you can select the part you want, and turn its opacity to zero in the surfaces tab; it may not be noticeable in you render, even if parts are visible elsewhere because they need to be, due to the camera angle you have. Use the surfaces selection tool to select the part you wish to make 'invisible'.
