Non-photorealistic Renders (NPR)
11011131516100
  • 3Diva3Diva Posts: 11,981
    I downloaded the beta of GIMP 2.9 for Windows and took a look at the NIK Collection.  Very nice filters.  I thought I'd post a couple of images.  Of all the filters I've tried so far, I like the first image the best.  The second image was done with GIMP's Cartoon filter.  It looks like they may have made some changes because the same image done with the old filter in 2.8 doesn't look the same.  I still have a ton of filters to play with that I haven't tried yet.  I think both of these counts as NPR images.  I'm still trying to figure out where the lines gets drawn between real and NPR.
    I have more realistic images with the filters I tried posted in my Laboratory thread.
    Oh nice! I really like the first one. It looks almost like a charcoal drawing. :D
  • KnittingmommyKnittingmommy Posts: 8,191
    Doesn't it though? I think that's why I like it so much.  I used to do charcoal sketches, but mine were never quite that good.  :)
  • nonesuch00nonesuch00 Posts: 18,773
    I could draw like that once. It took a few years of drawing comic books as a child before I got that good. I can't any more. There may be such a thing as natural talents but I'm no one of them.
    I tried a couple of toon shader presets in DAZ Studio today and they were far too realistic. What I was really wanting was a water color sketch so I'll do as in this thread and render to iRay and use the Nik filters and see what I get.
  • djigneodjigneo Posts: 283
    edited August 2016
    I started working on some examples of different styles using my toolset. This is something (a possible promo image) I came up with recently, trying to use freebie DAZ assets so I could make a tutorial later.
    Edit: Attaching the file seemed to not work because I had an '&' in the filename. =P
    1300 x 1000 - 1M
    Post edited by djigneo on
    Edit: Attaching isn't working right now, so check this link for now.
    That looks nice! That toolset looks like it's coming along quite well!
  • Oso3DOso3D Posts: 15,090
    I was really planning on doing a bunch of realistic Iray supers renders, but I keep ending up enjoying B&W lineart style more.
    Latest:
    1080 x 1080 - 612K
    Latest:
    Oh nice! That looks good! I can see that being colored and published in a comic. Very cool. :)
    Do you think it'd look better with color?
    Well I'm a comic book colorist, so I tend to think most things look better in color. lol I'm biased though. :P
    Heh. Well, doesn't hurt to try. Meanwhile, here's another render from same concept of a team of black superheroes (Code Blue).
    1748 x 1080 - 363K
  • pdspds Posts: 593
    This looks fantastic, Will! Was it rendered using pwtoon?
    edited August 2016
    Thank you! Yes, it was. Getting a flat B&W (or color) way is not hard: set all colors to white, turn on lines, set diffuse upper threshold to 0% (eliminating shading beyond B&W), and then be sure to use no-shadow lighting. I find a single distant or spot light works nicely. I sometimes use AoA Ambient light (usually with AO off unless I want a little shading) to go from hard B&W to 3-4 tone gray.
    I've experimented with a lot of different stuff, and while it has certain limitations (namely the whole 'seeing objects edge on looks completely black' issue), it does a great job in most of the ways I care about.
    Diva, here's another version of Calcine, this time with color (and a little bit of AO to add shading). What do you think, as an expert?
    1080 x 1080 - 1M
    Post edited by Oso3D on
  • ToborTobor Posts: 2,300
    Will, You're getting really good at this! Nice work. Keep it up.
    edited August 2016
    That looks great, Wil! I'd love to see it pushed a little farther though, with slightly more dimension. Perhaps something like this:
    Forgive my quick and messy coloring, I didn't have much time to spend on it. I just brought it into PS for a couple minutes and did a really quick paint over to show you what I mean (I hope you're not offended). :)
    Post edited by 3Diva on
    Not at all. ;)
    It's just funny, since I've been fighting 3D to get it to look 2d. May have overshot the mark. ;)
    Here's one of Tensor Tam. I may redo Calcine to see if I can get more of that effect.
    (I'm trying to do it with minimal postwork, but that's always an option)
    1748 x 1080 - 1018K
    Yeah, Will. I'm digging this latest style of yours. Very clean, and I think it's a look that definitely works!
    Better, or worse?
    1080 x 1080 - 1M
  • WillowRavenWillowRaven Posts: 3,787
    Latest:
    I love the clean lines.
    The hair looks so real in this one ...
    This style would also work great for children's books, especially for older picture books (transitional or middle grade). But I'm not really following your steps. Would it be too much for a more specific set of instructions?
    Better, or worse?
    This latest version looks even better.
    Ok, with PWToon there is 'diffuse upper threshold.' Thresholds basically control how shaded things look. With the two thresholds the same, the shading is binary -- Diffuse color/Shadow color. If the thresholds are different, there is gradiation between the two.
    For my strict B&W stuff, I keep both thresholds at 0 and rely on bump/displacement to add fiddly details.
    Also, ambient light has an Ambient Occlusion value, which, again, creates an impression of shading. For 3-4 tone images (black, gray, white) I rely on no AO, just an even lighting so that all shadows are gray and the black comes from outlines.
    With the last image, I used some threshold (75%) and AO to create some shading.
    I want to avoid the issue of ending up with shading looking like 'cheap 90s CGI art.'
    One approach I might want to try is to make a 'shading' render image of everything EXCEPT color and outlines, and run it through some sort of 'make it look penciled.' Mmm. I'd rather not, but... it would avoid overly generated-looking shading.
    Better, or worse?
    Better I think, but how we're more back toward a 3D look. lol It's a difficult dance - getting 3D to look 2D. I think the best option right now until the programs are "smarter" when it comes to creating 2D looks, is to do the "lines" from 3D but then hand color the image. That's just IMO of course. :)
    Another member of Code Blue, going with the semishaded style.
    1080 x 1080 - 478K
    Is the color on a seperate layer from the lines? If so, perhaps you could hit the color layer with a very subtle blur. This would get rid of some of the harder/sharper shading and might help it look a little more like a hand colored look perhaps? :)
  • DollyGirlDollyGirl Posts: 2,701
    This is such a fun thread that I thought I would try my hand at doing this. So my approach was to post work. I started with an iray image. Actually I rendered out the background and foreground seperately. Then using Filter Forge filters I tried to approximate water coloring. I did the post work in PaintShop Pro X6. Making layers of the different filter results from Filter Forge. It was a combination of cartoon filters, watercolor filters and art medium. Then using gaussian blur, drop shadow and a cloud brush to soften edges and remove some of the pixelating that occured during the filter use portion of the project. Not as amazing as some of the others images in this thread. I had fun though!
    edited August 2016
    And just for fun too these two images are about Hildy Johnson and use Eustace Scrubbs' half tone shaders.
    Post edited by Chohole on
    edited August 2016
    Those look very nice.  I love the last two.  They remind me of old advertisments that were done in that style. I haven't them but haven't managed to play with them much.  My results haven't been near that good yet.
    Post edited by Knittingmommy on
    Filter Forge is a wonderful tool. I use it a lot myself. Great job, btw.
    Thank you both for your kind comments.
  • RuphussRuphuss Posts: 2,631
    hey DollyGirl
    nice stuff
    seems like a lot of us 3d artisans have an old  longing changing back to 2d pictures of our childhood
    2 statements i often read here:
    wow looks like a real photo
    or
    wow looks like painted
    very seldom
    wow looks like 3d art
