Problems with "Wear Them All"
I just purchased the Wear Tem All Autofitting Clones and Clothing Smoothers for Genesis 3 Female and Male in hopes of using all of the older clothing on the the new figures. However, the only Autofit options I am getting for Genesis 3 figures are the default ones. The additonal "clones" for Genesis, Michael 4 and Victoria 4 are not showing.
I have performed a "Scan for new" within DAZ Studio. I have restarted my computer, and performed a full shutdown and second scan. Still not showing up. Is there something I'm missing from the install?
  • barbultbarbult Posts: 27,504
    Did you install the product with the Daz Install Manager, Daz Connect inside Daz Studio, or manual installation?
  • TymefyreTymefyre Posts: 16
    I used the DAZ Install Manager. I'm going to try to re-install in the morning. If that doesn't work I will try the DAZ Connect.
    What version of Daz Studio are you running, and what operating system are you using?
    In the Daz Install Manager, go to the Installed tab. Right click on the product name and select Show Installed Files. Then click on one of the file links in the list (for example, /data/DAZ 3D/Genesis 3/Female/Morphs/VAlzheimer/Genesis 3 Female Clones/Genesis 2 Male Clone.dsf). A window will open to show you the contents of the folder containing that file. What is the full path of that folder (what are the folders above "data")?
    It was showing as installed but was not functioning. I uninstalled the package, and did a full restart, then installed the package again. Just ran a quick test and it is now showing all the options. I was able to fit the Teen Swag to a Genesis 3 Male figure. Thanks everyone.
    Good!
  • donalddavisdonalddavis Posts: 95
    Installing DAZ items has become an exercise in frustration in the past year, not the specific product, DAZ needs to do more to fix the entire CMS mess post Connect as it is turning in to an exercise in utter frustration and wasted time.
    I installed Wear Them All using DIM.  Only the instructions are installing.  All of the other items completely fail, they have the gray image with the U.
    Uninstalled, reinstalled with resets etc, does nothing.
    Reset the CMS DB, reloaded everything.  Everything works except Wear Them All.
    Uninstalled broken version and tried Daz Connect.
    The items do not appear in Daz Connect, I honestly think the DAZ Servers are malfunction here.
    I tried the Daz Connect manual/offline mode installation, the files are there just like the DIM install but not showing up anywhere in the prooducts or content libraries.  There is not even an install option.
  • Richard HaseltineRichard Haseltine Posts: 111,390
    Wear Them All doesn't have user-facing files, other than the instructions, it adds options to the AutoFit dialogue.
    edited May 2017
    Yeah, I understand that but it was showing up uninstalled and when I added clothing a lot of the options were missing.
    I managed to fix it but I am not sure which step did the trick.  I reinstalled and uninstalled it with DIM and the Daz Connect option came up, so I installed it via Connect and seems to be working now.
    Thanks for the help.
    Post edited by donalddavis on
    It's working pretty good for me but I am not sure which takes precedence in the 'autofit' choices in the case there is overlap between 'Wear them All' and DAZ Studio's own autofit and it seems like I had one other product that does that stuff but I can't remember the name of it.
  • greymouser69greymouser69 Posts: 501
    Well there was crossdresser (XD) by evilinnocence and wardrobe wizard by philc and even Clothes Convertor available here.  WW was included in poser from version 8 on and XD was a stand alone program freely available where you only paid for a licence for figures to be converted TO instead of both.
    I was thinking of Cross-Figure for G3F - G3M & same for G2M - G2F. Also I had bought 2 products that allow V4/M4 to be worn on G2F/G2M. LOL, I think I have some overlap there but it still works. I think Wear Them All added V3/M3 and some others to the mix although I don't recall seeing those in the drop-down menu.
    The original wear them all products (1 each for G3F & G3M) gave genesis 2, genesis, V4 & M4.  The expansion gave V3 & M3, etc.
  • A couple of days ago I installed "Wear them All", as soon as I play with it, I'm so in love with it. I have so many V4 cloth and I can autofitted on G3F perfectly. I even morphing the figure's body and the clothes is following the body perfectly. Save it as subscene set, and load it, the result is still the samme as I saved it. Until I update my DS to 4.10, everything is change. It's like the autofitted is not always following some part of the body morphs. The body's figure is clipping thru the clothes. As I recall, "breast size", "voluptuous", "Heavy", and "Weight" (it's all from "Genesis 3 Female Body Morphs) is not affecting almost all of V4 clothes when it autofitted to Genesis 3 Female Figure. And all is happen since I update it to DS 4.10. Is there something did I do wrong? It's almost like I really want to go back to version 4.9.
    I attached the render, left one is before update, and right one is after update.
    923 x 850 - 452K
    917 x 844 - 540K
