Tin Pan Alley issue
I can't find Tin Pan Alley from Stonemason. I have reinstalled it from Daz manager and I don't see results. I even have reinstalled daz but nothing crying
There are some files that I can't install "CA" and "VUE" (Image attached)
Thanks!
  • JUJUJUJU Posts: 1,133
    CA means Carrara, Vue means Vue. These are other programs, so you don't need this files in Studio ;)
    I have Tin Pan Alley and will have a look, where the files go. I install most stuff manually, so I hope, I can help you and the files are at the same place as they are installed over manager :)
    Ok, look at Probs - Stonemason -  TinPanAlley
  • I look in props but I couldn't find it crying
    How can I install something manually? I have the files in my desk
    Thanks!
    232 x 146 - 3K
    You have to extract the file. Then there is a folder "Content". Put all folders from there in the folder "My Library" you use in Studio.
    Here is a video tut about
    But I do it more easy: In the content folder I pick all folders there and past them in My Library.
    First you can have a look in the folders to see, where you can find the stuff in your Library.
    I hope this helps.
    548 x 197 - 25K
    Here you see what is in Content and on the other pic the folder My Library in Studio
    617 x 234 - 43K
    526 x 495 - 81K
    In the Instal Manager, when you have installed it, right click on the file and you'll see an option to see where the files get installed to. They are also links so you can even click on them and it'll open up the folder they get installed in.
  • Found it! but I found it in a sub sub sub folder in "My content". There is a way to see it in "Smart content"?
    Thanks!laugh
    1280 x 728 - 599K
    1280 x 728 - 260K
  • Charlie JudgeCharlie Judge Posts: 13,399
    edited August 2016
    Thanks!laugh
    Environments > Cityscape
    Post edited by Charlie Judge on
