Poser 11 pro - kinect addon shown in files but not in poser addon menu
Hello, So i have a poser 11 pro, fully updated with the manager, I desperately need the kinect function to work, but its not showing in the windows/addons menu...I had a look in the files and found the realted kinect files , but they are simply not loading up in the main program...
I have no idea what to do, i simply am stuck without a clue.
Is there a work around to get his loaded?!
  • faisanfaisan Posts: 602
    I have the same problem :(
  • There is a seprate installation called poser support files.  That installation contains the kinect feature and a bunch of little addons.  Run the Poser support files installation and that should fix your problem.  I hope this helps.
