hi i need help does anyone know how to use these gloves
lasagnaman
in The Commons
hi can someone tell me how to use these gloves
i dont know how to use them
You need to select the character and apply them. They are a second skin products, meaning that they will work directly on the skin, replacing the original skin.
So, my steps would be:
There's also a note in the readme: When changing out second skins, be sure to reapply the character's original base texture before adding the second skin.
http://docs.daz3d.com/doku.php/public/read_me/index/31347/start
i think they are a 'second skin' type product. they have no geometry etc. afaik, you apply them from your materials folder, just select your figure in the scene tab and either double-click or drag and drop to apply them.
I don't have the gloves, but I do have other Sexy Skinz items. As mentioned above, select the character you want the gloves on and double-click or drag-and-drop the gloves you'd like her to wear.
Sexy Skinz then applies a second layer via LIE. (You can access the LIE, Layered Image Editor, by clicking on the image box of a parameter, in this case, the Base Color.) The product also makes changes to some of the other images. Be sure and check the Displacement parameter. If there is an image there, you might want to set the strength and change the SubD Displacement Level to 2 or 3. I believe the Minimum and Maximum Displacement defaults are probably okay for something like lingerie or gloves. These products do not affect Normal Maps, so if you want or need the height, such as the laces on the gloves, you'll need the displacement.
You can remove the Sexy Skins gloves via LIE. Although if you haven't made any other changes to the character's skin, it may be easiest to reapply the character's skin materials, as BeeMKay pointed out. Ctrl+z, (cmd+z for Mac?) works, too, as long as you haven't made any changes since applying the gloves.
