Purple Iray Renders
Hello,
I am not sure what happened, but suddenly all of my Iray renders are purple! It was working fine yesterday. All scenes I open render with a very strong purple cast to them. I restarted DAZ and restarted my computer, but still the same. I restored all of the render settings to default, but nothing helps. For example, I loaded a very simple object, a garden planter. Used the default Iray settings and Dome and Scene. I render and it turns out like this...
I am using Windows 10, and have a 980ti graphics card. Like I said, everything worked fine yesterday, not today I am stuck in a purple haze.
I hope someone can help!
Thanks
  • I also ran the render with just CPU, and the results were the same, so it isn't a problem with my graphic card.
  • barbultbarbult Posts: 26,380
    edited July 2016
    I think this is caused by your anti-virus deleting a required file. There are a couple other threads about it in the forum. I'll see if I can track one down.
    Edit: http://www.daz3d.com/forums/discussion/98756/iray-pink-render-problem-solved
    Post edited by barbult on
  • Wow, great thanks. I had been searching the forum for purple render problem, I guess my color vision is a little off. I remember my antivirus finding an infected file, I bet it was the freeimage mentioned in the thread.
    Thank you very much for responding to my plea for help!
