Stonemason: permission requested - Superfly mod for Level 19
     I've made Superfly material setups for some of your scifi models.
     Level 19 has those P4-style texture maps which lose detail and look blurry if you're up close. To give it fine detail yet retain your stenciled markings, I made discriminator maps to control the replacement of the original P4-esque texture with my own non-repeating tiled material. This pic shows a texture map (left) with a discriminator (right).
alt text
     Where the discriminator is light, my non-repeating tiling shows; where the map is dark -stenciling, stripes- the original map shows. Notice that the octagonal striped areas are black except where the paint is worn away; the worn areas will show non-repeat tiling.
     I also gave metal areas Superfly metallicity, and made the luminous surfaces cast light.
Level 19 - Superfly Level 19 cargo bay doors - Superfly
     I would like to release the Superfly material setup as a freebie, but the discriminator maps may be considered derivative, so I won't release this Superfly MAT of Level 19 (and cargo bay doors and elevator) unless you give permission.
     Thank you for consideration.
Post edited by Chohole on
    Level 19 - http://www.daz3d.com/level-19 - is a Daz Original.  While Stonemason made it, it is owned by Daz3D and therefore you need to make your request to them.  Best bet is to open a ticket wiht the request
  • SigurdSigurd Posts: 1,095
    Awesome!!!
  •      Heya, Mattymanx!   Thank you for the response.  Took me a while to find the thread, sorry.
         I made a new material set which doesn't use derivative maps;  the nodework would frighten the Borg, but it removes the redistribution issue.  I have some server blades running test renders now.  If the results are decent, I'll release this version, and maybe a few add-on pieces which allow for viewing through the door glass or the bay's opened doors.
         Thank you, Sigurd!
    Look forward to seeing more pics. Gives me some ideas of my own.
  • edited June 2016
         It will take some time for the Level 19 tests to render.  But here are some Superfly adaptations of other Stonemason sci-fi stuff:
    The Arc
    Last Jedi standing
    Cortana
    Urban Future 2
    sparring
    Post edited by sarah_dalmation_456056469c on
  • Test renders of the release-able Superfly material setup for Level 19:
    This shot shows both of the doorsets. The doors on the left have a solid wall slab behind them, so I made a billboard to slip in just behind the doors; the billboard uses LightPath ambient boost and actually casts light into the Level 19 main room! :D
    The doors on the right can be opened/hidden, and I made a T-shaped corridor to give the camera something to see through the door glass (or if you have the doors opened).
    The new corridor add-on:
    ...and the Superfly adaptation of Stonemason's cargo bay doors add-on for Level 19:
    I'll get this packed up and posted on ShareCG as time permits.
    Something like this for Daz users?
  • jcbunnjcbunn Posts: 271
    edited July 2016
    Yes it is, THANK YOU sarah_dalmation_456056469c
    http://www.sharecg.com/v/85501/browse/7/Material-and-Shader/Superfly-MAT-for-Level-19-cargo-bay-doors
    Post edited by jcbunn on
