What is the Non-Photorealistic Render seeing in eyelashes?
BC RiceBC Rice Posts: 591
edited October 2012 in Carrara Discussion
I feel like I'm missing something with the Non-Realistic render function.
I draw all of my own eyelashes, so there's no reason that the "default" render should issue out those horrible-looking eyelashes the way it does.
Is there something I need to do to make the eyelashes NOT APPEAR in the Non-Photorealistic render? I feel like I've tried everything I can think of.
Thanks!!
EDIT: Oops -- this should be in the Carrara thread.
Post edited by BC Rice on
    Moved to Carrara Discussion forum
    edited October 2012
    hi what's wrong with ugly square eyelashes?
    well I always clean my up in post but judging from the square shape they are transmapped polys, so you are getting the poly outlines - so I would add a morph in the vertex room or just puill them out of the way - so
    in vertex room select by shader>eyelashes then scale them down or push them in the back of the character's head - you could justchange the mesh or do it with a morph
    I suppose ifg you were very clever you could just use the scale tool in the x/y meridian and make them really thin so they still draw but look like eyelashes
    Post edited by Headwax on
  • BC RiceBC Rice Posts: 591
    Hm. This might help me in other aspects as well. I've always been unable to fiddle around with a DAZ model in the modeling room with the exception of the displacement brush. Never understood why that is.
    I'll give this a go on the eyelashes for sure, though!
    Thanks!!
