Mac: Reinstall - PostGreSQL CMS Connection could not be Established
ScavengerScavenger Posts: 2,674
edited June 2016 in The Commons
I've had to refomat my Mac because of reasons.
I reinstalled Daz by copying everything from the backup to the new image.. it worked fine, EXCEPT I get an error " PostGreSQL CMS Connection could not be Established...etc" when I start up, and there's a "login" button hanging out....
Can someone had to advise how I fix this?
Post edited by Scavenger on
  • Pack58Pack58 Posts: 750
    edited June 2016
    Search your system and make sure postgres.exe (or whatever the mac equivalent is) is installed, if not redownload postgres from your products and install. https://www.daz3d.com/downloader/customer/files/prod/18869
    And if it is there some one else is bound to come round and help.
    Oops reread the screen cap and it the lack of a connection so possibly not the same issue I had.
    Post edited by Pack58 on
  • Richard HaseltineRichard Haseltine Posts: 109,598
    edited June 2016
    Also, it's possible that your cluster directory and/or port names don't match between the new isntall and the back-up which can block communication. Got to
    Application Support\DAZ 3D\CMS
    open the cmscfg.json file in a text editor, then open the ContentCluster folder and from that open the postgresql.conf file in a text editor. Check that the entry for Cluster Directory in the first is pointing to the CMS folder - if not you may need to find the folder it is pointing to and open the postgresql.conf file there, but I'm not certain of that so check both in that event - and that the entries for port match between the two files (ignoring any lines starting with a #).
  • ScavengerScavenger Posts: 2,674
    Both ports are the same.
    Do I remember something about turn on/off the cms system?
    Theer are on and off commands in the Content Library pane option menu, but I doubt that's relevant here.
    Ok.. running into this problem again....
    There's a green button that says Start CMS showing at the bottom of the Smart Content pane. Clicking it doesn't seem to change anything.
    The CMS Settings in preferences matches the settings in the CMscfg.json file and the postgresql..conf file..
    Anyone have a thought on this?
    175 x 193 - 11K
    793 x 211 - 32K
