How to add scripts to a figure?
I hope I am putting this in the right place. I recently purchased Fit Control, (http://www.daz3d.com/fit-control-for-genesis-and-genesis-2-female-s) and I am still a newbie at this. I was reading through the included documentation, and got to the point where it says to select the figure wearing the clothing you want to adjust and then clicking the add script icon, which is apparently a plus sign. I have been looking through the UI and the menus, but I can't find where this option is. Can anyone give me some advice where to look to find this?
Thanks.
  • LindseyLindsey Posts: 2,016
    You'll find the scripts in:
    Genesis>Clothing>Fit Control and
    Genesis 2 Female>Clothing>Fit Control
  • edited December 1969
    I found the scripts themselves. What I can't find is where in the UI to actually add the scripts. I don't see the button mentioned in the tutorial anywhere. I am using Daz3D 4.8.
  • Tramp GraphicsTramp Graphics Posts: 2,429
    That "should" probably be in your Content Library Tab In Daz Studio Formats>My LIbrary>Scripts
    edited June 2015
    Here's the Genesis Fit Control scripts in the DAZ Content Library. You don't see this? Once the clothing is applied to Genesis, select Genesis and double click on the + icon to create the Fit Control morphs on the clothing.
    The three groups of Fit Control generated morphs are on the Parameters Tab for each piece of clothing under Actor>Fit Control
    606 x 520 - 61K
    605 x 591 - 39K
    Post edited by Lindsey on
    Awesome, thank you very much! Found it!
  • kesiafevielkesiafeviel Posts: 23
    Adding another thank you!! Thanks to your screenshot, I also found a shortcut--just search "fit control" in the Content Library window.
    Much obliged! laugh
  • AlienRendersAlienRenders Posts: 806
    Be careful with Fit Control. It's a nice tool, but it'll make your scene files huge. You should delete any morphs it creates that you don't need to keep the file size down.
