My Renders, Now I can go to bed
18911131417
  • XaatXuunXaatXuun Posts: 874
    edited May 2016
    had an idea for a couple pose, so jumped right on it, pretty close to my idea, unfortunately  I don't really have clothes for them, that I would use for that moment, so only rendered the the portion thast would allow me to post it here winkAlso not a decent Background
    my models, that  I had dialed in with morph dials (G3F L Petite & G3M E)
    1600 x 1598 - 2M
    Post edited by XaatXuun on
    edited May 2016
    okay here is that pose, she  had to use G2F clothes, so simple fix there wink. There was something else I wanted to use for the G3M, but I had not yet downloaded it or transferred from old comp
    I couldn't get that same lighting, would need to work on that more, lighting in Iray seems harder for me to adjust, then it was in  3Delight
    1600 x 1598 - 2M
    edited June 2016
    testing some Iray shaders
    1600 x 1600 - 549K
    edited June 2016
    building some new poses, still needs some fine tuning, before saving as preset pose,  think I have the expression part done
    1600 x 1598 - 908K
    edited June 2016
    break to  do a G3M . . actually it's a M7, but then  I added . . then played with dials,  and ended up with G3M F
    trying some shaders to get a effect for the Blades, needs  some work frown
    1500 x 1502 - 294K
    edited June 2016
    toyed with the blades, used  different one's this time,  got closer to what I was working towards
    1500 x 1502 - 1M
    edited June 2016
    lack of sleep, creates this
    1600 x 1598 - 2M
    edited June 2016
    G2F . .Iray, Scene only . . 3 spots (1 for back light),1 distance, 1 Point, Still not right, but getting sleepy.
    I was getting closer to what I was wanting . .  I recall or think I recall, there was a way to not show shadows from every light in Iray, too tired to search right now'
    I don't have any morph dials for G2F, but I do have a couple freebie character dials , so she's a mix of them
    In the spot
    1600 x 1600 - 1M
  • SaphirewildSaphirewild Posts: 6,680
    Some very excelent works there Xaa!!! Very nice models and charactors!!!
    Thank you
    It was the first time I rendered Iray set to 'Scene Only', and WOW, it renders super fast
    but it needs a lot more light intensity , then what one would use in 3Delight. It givers me  some reason to play in DAZ Studio more now, discovered something new to play with,
    edited June 2016
    still playing with lighting for Scene only Iray, though have to admit I almost wasn't going to post this, after I sign in, click to Art Studio, I get the Friggen Signing out, happens every damn day.
     It don't happen if I'm on someone else computer, I stay logged in for ever
    okay  done screaming
    here is my latest attempt working with lights, still needs lots of work, and discovering
    One is without adding lights, just using headlight
     the other was with added lights
    a new Morphed G1F, I don't remeber which Mat I used but I think it was Riley
    first is the  lights I did
    this one is just the Headlamp, No lights added
    as you can tell I still need to work on it, I do best learning  by discovery, but sometimes need mini directions
    1600 x 1598 - 1M
    1600 x 1598 - 1M
    edited June 2016
    I was supposed to be playing with them thar lights for Iray Scene Only renders, but instead I dialed in another G1F  (named G1F H)
    just a plan jane Iray render, Some carbon fiber shader, and a Latex, and a Satin shader
    Such a petite Sword for the Young lady
    1400 x 1397 - 1M
    edited June 2016
    okay, after that last post, decide I best get back to them lights
    I used the same lights, I used  up above,  just had to move them
    3 spots (one for backlite), 3 Distance
    one spot was moved to just target the Dragon, the other spot just on G3F
    2 renders, one  with Dome & Scene, and another with just Scene
    Dome & scene took 20 minutes, the Just scene one 2 minutes, I like how the Dome & Scene one came out
    Calling this one :   Sentinels
    .This is the Dome and Scene render (had to use another site, for some reason it was juist loading and not loading got tired of waiting after 10 minutes)
    This one is Scene only
    1660 x 1660 - 2M
    edited June 2016
    A Freebie I picked up the other day, used some shaders for the changed look
    1660 x 1660 - 2M
    Where pray tell did you get that amzing freebie??? Love the looks of her!!!
    edited June 2016
    can be found here shukky's_Humanoid Bco_ver2  , at ShareCG
    edited June 2016
    I should also mention the metal shaders I used were also Free Xcetra3D - Basic Iray Metals [Free] ,
    edited June 2016
    just a new G3F I dialed, using V7 Iray Mats
    made this one to practice settings for making for a more realistic skin,  I like the mats used now, but  seeing at a close up,  could use some adjustments.
    we'll see or not . . . .  if I can do it
    1660 x 1660 - 1M
    edited June 2016
    was done outside, came inside, and had nothing to do, so  I did this
    I should had played with the shirt some more, but  it's now getting late
    1800 x 2302 - 2M
    fixed the shirt,  like it was meant to been. might try something else  with it, later
    I was trying to find where I found that freebie shirt from, there is a lot that can be done with it, you just have to add your own mat's or Shaders to it (I used both)
     found freebie, Rain, thought I add that too and see what it looks like , been forgetting  to try it out. guess it was not  really rain for Iray, looks like it's raining Oil indecision
    I think I got the rain from DNA freebies,  since the folder that are in  is titled DNA_Weather
    Apparently this site is having issue with uploading so had to use another to host the image
    edited June 2016
    just  playing with some dials on G3F
    end result was this
    1600 x 1600 - 869K
    edited June 2016
    been seeing a lot of  melee weapons rendered lately . . kinda  going to jump in and do one too
    had to use a outside site to host image,  this site is being grumpy again
    edited June 2016
    Nothing special here.
    Just making sure I had not lost how to use 3delight
    Genesis 1 Male morph, some dials to adjust body type
    1600 x 1600 - 794K
    attempting to get me a light set built again
    and seeing how it looks in 3DL, Iray Scene only and Iray Dome & Scene
    1600 x 1600 - 1M
    1600 x 1600 - 654K
    try that dome and scene one again
    Gave up waiting after 18 minutes wating for it to load, maybe this time it'll happen,  if not, I'll try again later
    gave up for it to load after 8 minutes, I'll try again later to upload it
    trying again see if it happens this time
    5 minute still not loaded
    try again later
    see if  it'll upload this time
    26 minutes of uploading and it's no bigger then the 3dl one, which had not a issue uploading
    heck just tried a few other's and nothing is uploading
  • IceDragonArtIceDragonArt Posts: 12,943
    Did you try logging out and back in?  Sometimes that does the trick
    that's funny . . this site logs me out twice a day sometimes, I don't need to log out, it does that already ..  even after I'm logged in, frustrating as hell
    any more I just log in when I have something to show,  don't even come to the site any more unless I have somethng to show.  if it wasn't for the email notifcation , wouldn't be here now.
    each of those attempts was a new login, so logging out then back didn't fix it
    in the past I had just used another site to host the image when that happens, but this time I just figured DAZ didn't care and it wasn't worth it this time to use another hosting site for the image
    it did look better in the Dome & Scene, more realistic like then in 3DL, but I still thought the lighting in 3DL one was better, skin not so much, and it was 3dl skin mats surprise, which looked better in Iray
    edited July 2016
    trying a different direction with lighting . .thought I see if using Point lights  give me a better result
    in the Viewport the klighting looks just right, but after rendering still too dark , light intensity is cranked up, and still too dark for me . . tho I was going for a dark room, but I wanted the subject well lit
    Rendered in Iray Scene & Dome
    2 point, 1 Spot (all lights same color 255 . 245 . 184)  no light was used for back light so not backlit
    Genesis 1 Female with some dialed morphs, Celia Skin Mats
    Then added  a few other things to fill the scene
    1600 x 1600 - 1M
